Tip & How-To about Cell Phones
Reset your nokia communicator phone ie ..9500 ,9210i etc..using new tricks.
Now you can reset/reformat your phone using a new tricks...
1..removed battery
2.press shift ,+ ,F
3.insert battery and wait until the phone will restart..
Cell Phones Logo
my Nokia e52 won`t start
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 16, 2012 | Nokia E52 Smartphone
i've nokia N91 phone... i want to format my hard dive but this text appear "hard drive is not available"
hi,
try to format your phone by this tricks...
1..removed battery
2.press shift ,+ ,F
Apr 14, 2011 | Nokia N91 Cellular Phone
I typed *#7780# for reset Software but Mobile ask for lock code, But it is forgotten. How I solve it Please?
hi ,
try this tricks to reset your phone without entering a lock code...
1.removed battery
2.press SHIFT ,+ ,F
3.insert the battery and wait until the phone will re-start
if you find this helpful ,give us a feedback..thanks for trusting fixya..
Apr 13, 2011 | Nokia N93i Smartphone
sidekick 3
Want to clear out info on your Sidekick info (ie: to sell yours)?
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
SK3 - remove the battery while the device is on.
6) Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted.
You're done.
http://shop.sidekickskin.net/Sidekick-Tips-Tricks
Jan 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
302 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
