Tip & How-To about Microsoft Windows Server 2003 Standard Edition with SP1 for PC
How to Setup,Configure,Troubleshoot for VPN in Windows 2003 Server
Dear Friends,
In the below mentioned links you will be able to find the complete details about the VPN.The links provide the infomation about (How to Setup,Configure,Troubleshoot for VPN in Windows 2003 Server)
1. http://articles.techrepublic.com.com/5100-10878_11-5805260.html
2. http://support.microsoft.com/kb/323441
The above links provides the solution with the Pictures of the Configuration
Regards,
Aysaam
Microsoft Windows Server 2003 Standard Edition with SP1 for PC Logo
What is the difference between VPN-connection and Proxy websites?
While both a Proxy and VPN service will re-route your internet traffic and change your IP, they function slightly differently.
Think of a Proxy as a Web Filter. The proxy settings are applied to your internet browser whether you're using MSIE, Chrome, Safari, Firefox, Etc. When browsing the internet through a proxy server, all benefits with that server are used, for example, (Security, Speed, and Geographic Location). The proxy will only secure traffic via the internet browser using the proxy server settings.
Unlike a Proxy, a VPN service provider(Virtual Private Network) encrypts all of your traffic, replacing your ISP and routing ALL traffic through the VPN server, including all programs and applications. This also will use all benefits of the VPN server such as (Speed, Geopgraphic Location, and Security).
The VPN can be easily connected or disconnected with the click of a button.
In conclusion, a proxy server is completely browser based, and is not as compatible with certain web pages that use non-browser technology such as: Comedy Central,Zatoo, Fox OD, and Sky Player. However, a VPN will work with ALL internet based services, but will offer less choice on which applications will get run through your ISP, as with the VPN, everything is routed through that server when connected.
So, you can get VPN services from sources like HideMyAss, Super VPN, etc., Once you have enabled a VPN service, you can visit IP-Details.com and have an IP lookup to ensure the change in your IP address.
Jan 21, 2015 | Computers & Internet
ihave 134 errors in my pc
Most of the time such error are fake errors due to spyware. It would be helful if you provide more infomation on how that error looks and couple od sample errors.
I would suggest your to Run a third part freeware called CCleaner which cleans up some unnecessary things in your computer (Select all that you want to remove).
Then once the CCleaner completes its job Run a Disk Check. Follow below mentioned steps
Step 1: Right Click C Drive.
Step2: Click on Properties.
Step3: Click on Tools.
Step4: Click on Check Now.
Step5: Select both Disk Check Options and Click Start.
Disk Check starts as soon as the computer is booted.
Good Luck
Nov 18, 2010 | Computers & Internet
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
how to unlock my huaweii b200w modem?
Hi Geortravel,
Please provide some more detailed information about your problem with Modem in the comments section so that I can help you out to solve the problem accordingly. please mention your device model, system config, etc infomations
Thanks
Jul 03, 2010 | Computers & Internet
VPN connection issues
check if you can enable "VPN pass-through" on your home router.
try diabling its security features (firewall) one at a time and try afterwards.
last option perhaps try upgrading to the 5.06 version of the vpn client.
Apr 06, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
728 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
