Tip & How-To about Video Game Consoles & Games
XBOX 360 WILL NOT READ DISC SAYS OPEN TRAY
Eject the game from the cd console if in the drive make sure your xbox is on warm it up take the disc if it is dirty run under warm water all over the silver side of the disc till dirt and debris gets completely removed after still holding the disc turn off the water and use scott SCOTT brand toilet paper the straight kind and use about four sheets to dry the disc or use a blow dryer, not preffered prefreably scot toilet paper after the disc is dry and warm very dry take your clean index finger and remove the rest of the debris off the disc and when the xbox says open tray let it say close tray close it see if it says read the disc if it says read the disc then it is not your laser or the laser needs to be blowed off with an air gun or compressed air. Get it to say close tray and itll close it self, wait ten seconds turn off the xbox turn it back on and go to my xbox mash play wait for it to read the disc. THE DISC WILL NOT WORK IF IT IS DIRTY I reccomend running it under warm water (let dry on both sides while still holding it properly) use a non scratch cloth to clean the disc preferablly scott toilet paper the smooth kind, after it is dry put the disc in the console if youve tried the disc try a brand new disc it might definately work after it says read if it says play the game then its the disc. If nothing happens like it dont say reading disc then your laser is cracked corrupted, or it has debris on it or is wett. Dont let your laser head get wet because i told you to run it under water make sure the disc is dry and completly free of scratches and smudges. WASH THE DISC WITHOUT SCRATCHING IT. Dont put a wet disc in your x box. Mash the hard drive button down and release mash reset to recycle the xbox green lights. Remove all the cords fromt the xbox wait two weeks or shorter, I waited a month or more before i played my game and it worked after I cleaned it twice one time and a month later i cleaned it without soap and used luke warm water.Remember Open tray, press buttom close tray closing automatically should say read reading reading disc then play if does not read the disc then its your laser. If its your laser and you are sure its your laser do not remove the hardrive or any screws they can tell youve botherd it because that will void your warranty. go to www.xbox.com/support its a pdf file print shipping label follow the steps to repair.
Video Game Consoles & Games Logo
My games wont play and it says open tray
You have dirty laser or bad laser or dirty disc drive period. Try cleaning laser with qtip. If that doesnt work keep the disc drive apart and hook it up to the 360 make sure not to let your disc drive ground out anywhere on the 360. Hit eject button and close tray seeing if the laser even goes up with the tray. If it doesnt try greasing the rails and gears in there where everything slides.
Nov 20, 2010 | Microsoft Xbox 360 Console
xbox disc reader does not think a disc is in tray for xbox 360 games
This is a common issue.
1. Make sure your disk is clean. Dirty disk can cause disk reading issues.
2. Clean the drive with a CD/DVD laser cleaner.
3. Replace the laser. You can get a replacement from Ebay for $10-15. Make sure you get the right one for you drive. There are several different models.
May 09, 2010 | Microsoft Xbox 360 Console
xbox wont read disc
The laser could be dirty, or wearing out. Try to us a disc drive cleaner CD and see if that helps. If not, something in the drive (ie the laser) is going bad and will need a replacement. If you have warranty available contact Microsoft. If not, it's a rather simple process to change the drive and I'm sure someone local can get it done.
Jan 09, 2010 | Microsoft Xbox 360 Console
when i put a game in it says unplayable disc
This could just be a dirty lens, try a cd or dvd cleaning disk, and check your games are in tip top condition the 360 hates damaged discs, otherwise you may have a faulty spindle magnet or the laser could be on its way, the spindle is cheap and easy to fix (does it eject the discs) if so it's more than likely your spindle. if its your lens then a new dvd drive can be bought for around £20 online. If its under warranty just send it back
Dec 06, 2009 | Microsoft Xbox 360 Console
how do i download a game to my harddrive onxbox360?
enfia esse cd no seu cuuuuuuuuu!!!!!!!!!!!!!!!!!!!!!!
Jun 15, 2009 | Microsoft Xbox 360 Console
495 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
