Tip & How-To about Computers & Internet
How to Convert Video to iPad for Mac?
Now the new iPad is a much better device to videos on than any previous version of the iPod and iPhone, there are many people curious about how to get their video files into a format that the iPad can play. Well, there are a number of ways to do this, one of these programs is called the Mac iPad Video Converter Software.The program offers an excellent job for converting and editing videos for making them playable on the video iPad. Below is the step-by-step guide about how to convert different video into iPad-ready formats on Mac. Video to iPad Mac Converter Various Settings:
Adjust video image effects by setting video brightness, contrast, saturation, applying a built-in video effect and normalize sound levels of DVD.
Support video output settings, including resolution, frame rate, encoder, bit rate and audio output settings, including sample rate, channel, encoder and bit rate.
Step 1: Free download the Mac iPad Video Converter software, install and launch it on your Mac.
Step 2: Click "Add Files" button to load any Video format file. You can add more files for batch conversion. To merge files, you can check before the item "Merge into one file".
Step 3: Choose an output format for your converted Video to iPad Mac files in the profile option. Find a document to store your output file.
Step 4: You can click "Convert" button to start conversion progress. Because of the super features, this conversion only cost you a few seconds.
This professional Video to iPad Mac Converter is specially design for Apple iPad, aiming to enable iPad users an exquisite experience of viewing video entertainment on your iPad’s largescreen. If you find yourself saving and converting video on a regular basis, then spend a few bucks and get the software. Also if you want to rip and convert DVD movie to iPad, there’s another tutorial that you might like: How to rip and Convert DVD to iPad on Mac.
more information:video converter ipad,convert video to ipad,dvd to ipad mac
Computers & Internet Logo
forgot my password for my iphone 4s
What can you do to bypass and reset a forgotten passcode on an iPod touch, iPhone, or iPad? You can't recover your passcode. Good news is that you may be able to reset the passcode by restoring the device.
A) Previously synced your iPhone/iPad with iTunes? If yes, then try the following:
  1. Connect your device to your computer that you normally sync it to, and thus contains the backup files.
  2. Launch iTunes.
  3. Select Back up by right-clicking (or Control-clicking) the device.
  4. After Back up is completed, select Restore and then restore from your most recent backup.
If iTunes prompts you to enter the passcode when you connect to your computer (*), or if the above does not work, try the following option.
B) If you did not previously sync your iPhone/iPad with iTunes, then try following:
You need to force the phone into recovery mode and restore it as a new device to remove the passcode. To do this:
  1. Disconnect your device (iPhone, iPad, or iPod touch), but leave the USB cable connected to your computer.
  2. Turn off your device by pressing and holding the Sleep/Wake button for a few seconds.
  3. Launch iTunes.
  4. Press & hold the home button while reconnecting the USB cable to your device. Continue holding the home button until you see "Connect to iTunes" on the screen; this will also cause the iPhone to turn on.
  5. You should see the "recovery mode" alert:
"iTunes has detected an iPhone (or iPad) in recovery mode. You must restore this iPad (or iPhone) before it can be used with iTunes."
Now that your device is in recovery mode, you must restore the device. You may either restore it to a previous point, or set it up as a new phone. This will wipe all files and settings, including the passcode. If you see a message stating that your phone is locked (*) and you need to enter your passcode, just ignore and close this message.
Note: Make sure that you are using the latest version of Itunes before attempting this.
(*) Passcode error message: iTunes could not connect to the iPad/iPhone because it is locked with a passcode. You must enter your passcode on the iPad/iPhone before it can be used with iTunes
Jan 29, 2014 | Computers & Internet
179 people viewed this tip
David Payne
David Payne
