Tip & How-To about Computers & Internet
How to fix Blue screen of death (BSOD)
BSOD--- Blue screen of death So guys how to get your computer working if you get a BSOD...???
XXX0000000XXX
well first of all check the exact error code and figure out the cause of it,there could be multiple reason
Bad memory
Bad sector in Hard disk
Registry error
Virus/Trojan/Spyware
Keep the windows disk ready....u might need it
Try the advanced boot menu...
See if you can get through F8 key helps a lot
Try last known good configuration.....
If not then try Safe mode with command prompt,if you can get through then use the system restore u need to be a 'C' prompt by using CD command and then pen the restore console (%systemroot%\System32\restore\rstrui.exe)
Otherwise do a flee power
No go yet.....
Hummmm u need the disk bro
Boot with CD (f2 or F12)
Run Chkdsk /p and chkdsk /f on he recovery console
still no go................
Please comment buddy
post a reply
Computers & Internet Logo
how do i fix my computer with a blue screen that keeps shutting it off?
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
Post your OS please!
Oct 01, 2010 | Computers & Internet
BLUE SCREEN
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 06, 2010 | Dell Dimension E520 PC Desktop
customer get blue screen
Windows blue screen errors are mostly hardware or driver related. Check the exact error message on the BSOD screen and also check the event log to see the error details.
Based on that info you can find the solution.
Here is how to analyze and solve blue screen errors.
Oct 20, 2009 | Compaq Presario 2200 (292600-004) PC...
blue screen and the charger works sometimes
blue screen aka bsod. when you get this bsod it will show you stop error code. you need to get the code to identify the exact issue you're having. If the bsod occures after the dell logo issue might be the video card or memory. if the bsod occures after windows logo then if might be caused by a corrupted windows updates or windows system file corruption. if the bsod occured after dell logo then check your memory if you have 2 ram modules try to remove 1 ram first then try booting your system using only 1 ram, try to swap and isolate reseat and teach eash slot on each ram module. if bsod occures after windows logo then try to run a test for your hard drive Fn+Power. If no errors it might be windows file corruption which needs to be restored or re-installing OS.
Oct 02, 2009 | Dell Latitude D510 Notebook
every time i try to turn on my computer it shows bsod for a split sec and the restarts again? can u help?
You can configure Windows to not automatically restart when a bsod occurs. In the Control Panel, go to System and then select the Advanced tab. Then click Settings under Startup and Recovery. Clear the Automatically restart checkbox.
Now when the bsod happens, it will stay until you power down the computer. You can read the STOP error of the bsod and any potential file name. Now you can search for the exact error and solution.
This article on troubleshooting blue screen errors might help you further.
Jul 29, 2009 | Computers & Internet
231 people viewed this tip
David Payne
David Payne
