Tip & How-To about Sony Playstation 3 (PS3) Console
No display - how to fix
Hi there
The no display problem is very annoying as you check all your cables and everything is fine but still nothing shows up on the screen,
What is the no display error
Again this problem is pretty much what it say's, you know you have this when you have no display on the tv when the PS3 is all set up correctly
The Causes
The basic causes are cables not connected correctly or you have a cable that is not compatible with your Tv/PS3
It can also be PS3 settings that are not correct.
The bigger problem is the Display chip internally or hardware failure.
The Solutions
Solution 1
Ok so you can send the console off to sony they will collect it, repair it and send it back, this will usually cost you $150
Solution 2
My favourite solution is the PS3 repair guide, you can fix the problem within the hour, costs are below $40 and you don't need to be technical at all.
Solution 3
Buy a new PS3 console over $200 this is the last resort.
What is PS3 repair guide
Ok so this is how i learned so much about PS3 and got me into the job today of fixing PS3's
The basic PS3 repair guide: is a high quality Pictured ebook, with the most basic step by step instructions that will fix your PS3
A good PS3 repair guide: This will contain the above mentioned and will also have a website which you can get 24/7 tech suppot to help with the fix, A forum with over 60,000 user's who have been in you position and can help you. Also some have great step by step video's.
The PS3 repair guide Comparison site
Ok i want to introduce the PS3 Problems gone Website this will be pivital in helping you choose the best repair guide, to get the best head start in fixing your PS3 you need to see the best repair guides on the Web today.
Conclusion
Ok so get your ps3 fixed get back to gaming and if anything else happens to fail you have your back up with the PS3 repair guide as its your's for life.
Good luck and happy gaming
Sony Playstation 3 (PS3) Console Logo
monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
I HAVE THE BOSS BR-900CD AND EVERYTHING SEEMS TO WORK FINE BUT NOTHING SHOWS UP ON THE SCREEN. IT LIGHTS UP BUT NO DATA SHOWS UP. THANKS
If all other controls are working, check IF they have a "Contrast" setting for the display. When those are at end of range, the display often is blank.
Mar 21, 2010 | Boss Music
The S1G display occasionally shows no data. The autopilot works fine for hours then fluxgate seems to hang up.
Try to borrow a computer unit to detect if the fault is in the computer unit or the display unit
Mar 19, 2007 | Raymarine ST6001 S1G Hydraulic GPS...
1,073 people viewed this tip
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
