Tip & How-To about Office Equipment & Supplies
Windows Manual Printer Removal
There are times when a printer, even though you uninstalled it, will still stay in the system and affect programs or even the startup of Windows. When this happens you need to manually remove the printer. Here is how to do just that.
Uninstall the printer via control panel. Next you will want to check the spool driver location and registry settings.
Reboot the system in to Safe Mode via F8 at statup. Remove the printer from the registry:
locate the key below and remove the printer via its name:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Contro l\Print\Environments\Windows NT x86\Drivers\Version-x\printer_name
Next you will want to remove any drivers left over in the system. Locate the file location below and remove the directory named your printer model.
%SystemRoot%\System32\Spool\Drivers\
%SystemRoot% represents your system folder within your windows installation folder. Typically c:\windows\system or c:\winnt\system.
Reboot the system and see how it goes.
Good Luck!
how can i have hp psc 1510 driver and valid Win32
Here's the fix:
* First uninstall your current HP installation.*
Step one: Uninstall the printer driver and software
1.
Disconnect the universal serial bus (USB) cable from the computer.
2.
Insert the printer software CD into the computer.
3.
A prompt to uninstall the software displays. Follow the on-screen instructions to uninstall the software.
4.
Restart the computer.
Step two: Turn off the Terminate and Stay Resident (TSR) programs and other background programs
When the computer is turned on, a software group called the Terminate and Stay Resident (TSR) programs automatically loads. These programs activate some of the computer utilities such as the anti-virus software but are not required for the computer to function. Occasionally, TSRs prevent the printer software from loading so that it does not install properly.
In Microsoft Windows 98, Windows ME, and Windows XP, use the MSCONFIG utility to prevent TSR programs and services from starting up.
1. Click Start and then click Run. The Run window opens.
2. In the Open: box, type msconfig, and then click OK. The MSCONFIG utility window opens.
3. Click the General tab.
4. Select Selective Startup.
5. If there is a check mark next to Load Startup items, click the check mark to remove it.
6. For Windows XP systems only - Click the Services tab and place a check mark in the Hide All Microsoft Services box. Select Disable All.
7. Click Apply and then click Close.
8. Click Restart to restart the computer.
Unplug your USB printer cable and reinstall. That's it!
Visit the HP Help Documentation Page for this error.
Here's the text from their page in case the URL for this changes:
Issue
The printer software installation stops and the Printer Driver Unknown error message displays on the computer. This document applies only to products connected with a USB cable.
Figure 1: Printer Driver Unknown error message
Solution: Follow the steps below to resolve this issue.
NOTE: These instructions do not apply to Windows 2000 because the MSCONFIG utility used in Step two does not exist in Windows 2000.
1.
2.
3.
4.
NOTE: This step does not apply to Windows 2000 because the MSCONFIG utility does not exist in Windows 2000.
1.
2.
3.
4.
5.
6.
7.
8.
Step three: Install the product software
Listed below are several options for installing the product software. If the product software CD is not available, HP recommends downloading and installing the product software from the HP Website at www.hp.com.
Method one: Install the product software from the CD
1.
If the product software CD is still in the computer CD drive, remove it and re-insert it in the CD drive.
2.
If the software installation does not start automatically, follow the steps below.
1.
2.
In the Open: box, type D:\setup.exe, where D is the letter of the CD-ROM drive.
Follow the on-screen instructions to complete the software installation.
Method two: Download the software from hp.com
1.
Go to www.hp.com and click Software and driver downloads.
2.
Type the model number of your product in the Search box.
3.
Select the operating system of the computer to which the device is connected.
4.
Click the downloaded software to start the software installer.
5.
Follow the on-screen instructions to install the software.
Step four: Use the MSCONFIG utility to enable the Startup software
1.
2.
In the Open: box, type MSCONFIG and then click OK to start the MSCONFIG utility.
3.
On the General tab, select Normal Startup to automatically enable all features the next time the computer is started. In Windows XP, click the Services tab and select Enable All.
4.
5.
Click Restart to apply the changes to the computer.
Jan 20, 2015 | HP Computers & Internet
Why is my computer so slow and how do I fix it?
Thanks for the tips! I have other tips also for solving this problem, hope you think they are useful: - MSCONFIG can be used to manage the auto-start programs, and thus speed up computer boot. - Checking for virus and spyware is right. Virus and spyware can eat up a lot of space. - Using the built-in system tools is also effective, but time-consuming, even they are free. Everytime I try to do this, I failed because I got tired of waiting for the tool finish scanning. And I prefer to use a Windows registry optimizer, which also offer many tools and works faster.
Dec 28, 2009 | Computers & Internet
she gets an error message when booting up:: Fail to load language file
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
Oct 05, 2012 | Acer Aspire Computers & Internet
internal error 2718 roxio media manager pops up upon startup. I have deleted everything in the registry relating to it. i have used reg cure, system mechanic. I cant open system restore, user accounts or uninstall in add and remove programs. I am using windows xp professional
Make sure you are logged in to an account with administrator privileges.
Click Start, click Run, type "msconfig", click OK. In System Configuration, click the Startup tab. Uncheck anything relating to Roxio Media Manager. Click OK and reboot.
Be very careful when dealing with the registry. Most registry cleaners do more harm than good if not used carefully. The "Delete everything I find" attitude often leads to a slower computer than when you started.
May 13, 2010 | Microsoft Windows XP Professional for PC
how can I uninstall Adobe album starter edition 3.2
try to run at the startup configuration and disable the program then restart, What Operationg System do you used?
Feb 15, 2009 | HP Photosmart 3210 Printer
1,508 people viewed this tip
jasbo
jasbo
