Tip & How-To about Video Game Consoles & Games
What to do if you have 3 flashing red lights on your Xbox 360 Console?
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
Video Game Consoles & Games Logo
has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
red ring of death
HI, this is a AV cable fault. it is unable to be detected. follow the procedures below to correct this issue. of the procedure dose not produce results, this will confirm that the damage is severe, and you will need to contact Microsoft for a repair ticket.
Check Points
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Sep 04, 2009 | Microsoft Xbox 360 Console
power button is blinking red
if 3 of 4 lights are blinking red, you have a red ring of death and need to contact microsoft. this is distubingly common on some of the older 360 models.
Jul 11, 2009 | Microsoft Xbox 360 Console
xbox 360 3 red lights can anyone please help?
That has absolutely nothing to do with the Hard drive. The red ring of death is a standard misfunction with the Xbox 360. You will have to contact your local game stores to see if they do Red ring of death fixes, send it in to microsoft, or attempt to red ring fix it yourself.
Dec 12, 2008 | Microsoft Xbox 360 Console
xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
169 people viewed this tip
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
