Tip & How-To about Audio Players & Recorders
Getting a wire under the carpet the easy way.
Ever tried to get a wire fished under a carpet but can't seem to get there without yanking half the carpet up to hide the wire ? (Warning, do not do this with wires that carry current! Power wires that get walked on can fray over time and cause fires if they short out!)
Go to the hardware store and buy one of those simple twisted wire drain snakes. The small diameter ones that look like a coiled spring that is at least twenty feet of so in length.
Lift the carpet just enough on the edge with a pair of needle nose pliers to start feeding the snake under the carpet.
Cover the small end of the snake with a small strip of electrical tape so it doesn't snag and start pushing it towards the place where you want the wire to run. You can change the direction of the snake by twisting it and pushing at the same time. When it gets to the other side pull the carpet up just far enough to grab the end of the snake with the pliers and pull it through.
Attach the wire you want to pull and tape it, then pull it back with the snake.
Finish up by sliding the ends of the wire under the base board with a small flat screwdriver leaving extra wire on both ends then shove the carpet back under the baseboard with the screw driver. Step on the carpet to catch it on the tack strips making sure you don't impale the wire on the nails.
Wire is hidden out of sight. Carpet isn't messed up, and you are done in a fraction of the time using half the wire.
How do I remove the front and rear door sill cover plates on my 2004 Jaguar X-Type without breaking them?
There may not be enough room under the door plates. I suggest you lay the cable under the carpet next to the door sill.
Mar 29, 2013 | 2004 Jaguar X-Type
all warning lights come on in a 2005 sunfire
ther will probably be a wire loom connector under the carpet under your feet and if the water has been getting to it I would saf that it will be correded and rusted . Check the wiring from front to back and check all connections for rust and rot
Jan 29, 2013 | 2005 Pontiac Sunfire
Can I run accessory wire under gas tank to battery without taking tank off on a 2011 Heritage Classic (FSLTC)
Hi Sleepydoc, I would run the power wire through a piece of heat shrink first, then mount it on top of the frame backbone securing with zip ties, then terminate at a circuit breaker. Good luck.
Jan 12, 2012 | Harley Davidson FLSTC Heritage Softail...
Carpet is wet on the driver and passenger sides in the front of the vehicle.
The a/c drain is likely clogged causing water to drain into the cabin. There is a hose coming out of the firewall under the car on the passenger side. You can try fishing a wire through the drain hose to unclog it. Sometimes it will have a few bends in it making it pretty difficult to snake the hose up. If you can't fish a wire through the hose you can try a quick shot of compressed air through it. Keep your face clear of the hose, if it is clogged you'll likely get a few gallons quickly out of the hose.
If that checks out, do you have a sunroof?
Jun 24, 2010 | 2005 Dodge Grand Caravan
running wirer from driver seat to stereo dodger ram truck 2003
peel away the door seal to release the carpet abit and then with a bit of time and effort work the wire through?depends on how easy the carpet comes awya to how long it will take,once the wire is through just place it all back in reverse order
i hope this helps?
Mar 15, 2008 | Car Audio & Video
2,317 people viewed this tip
 Grubhead
Grubhead
