Tip & How-To about Computers & Internet
How to protect your Computer in rainy reasons
If your computer(s) is/are not in an AC room - it (not only computer any sophisticated electronics goods) may be damaged in rainy seasons due to moisture. Please put (2-3 Kg) Solid Lime beside your computer for 3-4 days and close your windows and doors most of the time. The chance of damaging the computer will really be reduced.
Computers & Internet Logo
i am living beside sea side. where humidity in the morning ranges from 63 to 79 and in the afternoon from 44 to 76 throughout the year. i have bought 15 in number LEDs sony bravia 50" for my operational room. out of which 5 have become non operational (no display problem). i have repaired these leds from company but again one or the other become defective with the same problem. the room is fully closed with 2 ac running 24 hrs a day. led remain on 24hrs aday. i have no idea why its happening again and again. if any body has solution for this than plz share.
I would suspect you have a power problem. Voltage too low or high can damage electronics very quickly. Voltage spikes also can fry TV's. Your power company can help. Monster makes a complete power solution with sophisticated filters and a power supply regulator that will keep power within specs but you will spend close to $ 1000 for this solution. I don't think Humidity is the culprit but corrosion due to salt is another matter. If salt is the culprit then you are out of luck unless you want to install the kind of air filtration system used for a shelter from Atomic Attack.
Using the KISS principal I would check the power first.
Sep 29, 2013 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
my respected sir ,when i start my pc icould not see any thing up to ten minits due to moisture, it is only in winter season or rainy season.what can it be cause ? plz help me!
Time and aging of the machine and it hardware components.When it is winter or rainning seasons tries to keep the computer on and running every two a day even u are not using it,too it is not to putting to much more pressure and stress on the the computer components to have start up cold and put on much more stress of the season of that year stress for hardware of the computer to do the powering of the computer to restart booting sequences again.
Oct 02, 2011 | Samsung SyncMaster 793DF 17" CRT Monitor
why do frog disapper after the rainy
The Egyptians believed frogs to have been formed from mud and water, a belief that seems to have materialized as a result of rivers flooding during the rainy season, at which time frogs reproduced in such quantities that thousands of tiny frogs and toads invaded walkways and public areas; they even entered private homes and in general were regarded as pests. This phenomenon was dubbed "Frog Rain", because such occurrences always happened after the first heavy rains of the season. As such frogs became associated with weather predictions because they would begin croaking just before rains.
Jun 23, 2011 | LeapFrog Leapster Electronic Book:...
Damage due to reversed polarity
hello unless you know something about electronics of course you may repair it ...this kind of equipment are so sophisticated take extremely care....i think it would be better to get a estimated cost.......saludos
Nov 21, 2008 | Audio Players & Recorders
No raster no audio,Zenith SJ 2065S5
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner. as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged. if supply is ok check for leaky or short parts in hor output. 1 hor. output transistor itself if it is replaced that may not be of proper matching. 2 diode& cap.in eht section. 3 clean print near eht. 4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours. 5 at last if all are ok eht or fly back transformer. re connect power to hor output after rectification
Sep 18, 2007 | Televison & Video
117 people viewed this tip
David Payne
David Payne
