Tip & How-To about Computers & Internet
HOT TIP
To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
Computers & Internet Logo
Hi MY laptop is running very slow
For the better performance delete cookies,temp files from the computer.
Uninstall all the unwanted softwares from the computer.
Run disk clean up
  1. Open Disk Cleanup by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking Disk Cleanup.
  2. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. If the Disk Cleanup: Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
  4. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
  5. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer.
.To run disk defragmentation.
1. Open the Start Menu. A) In the white line (Start Search) area, type dfrgui and press Enter.
OR
B) Click on All Programs, Accessories, System Tools, and then on Disk Defragmenter.
Increase the virtual memory of the computer.
How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
This will improve the performance of the computer.
Thanks.
Aug 20, 2010 | Computers & Internet
Hi, What do I do about "virtual memory low" , please and thanks!
7.Click Set
Aug 15, 2010 | Microsoft Windows XP Home Edition
how to increase virtuall memory
For Win XP;
7.Click Set
Aug 10, 2010 | Computers & Internet
How can I increase the memory for this computer
In Windows XP
7.Click Set
In Vista
Remember to choose the drive you would like to use to increase the virtual memory. In most cases it usually your C: Drive. You can set the initial size and maximum size after clicking the Custom size check box.Remember its better to keep the Virtual memory values the same.
Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly.
Jun 11, 2010 | Compaq Presario 700 470024-192 Notebook
Can't run Brain Play Jumpstart Spanish from Scholastic
In Windows XP
7.Click Set
In Vista
May 13, 2009 | Vivendi Jumpstart Spanish (72019) for PC,...
186 people viewed this tip
David Payne
David Payne
