Tip & How-To about Computers & Internet
GENERAL COMPUTER TIPS TO MAKE YOUR PC FAST WORKING...!!!
1) Store all files in one folder according to it's type :- The my folder option is provided exclusively for this purpose as it helps in tacking out the type of file you are looking for easily and also its mush easier to backup the files at once. Secondly it helps to run the machine faster.
2) Don't store your files in the root folder c:/ drive.... :- Its recommended to store your files in the other drives that you create, because C drive is formatted every time you format or re-install windows or whenever there is a system crash, as a result all your files are lost.
3) Uninstall the programs that are not in Use :- Running programs tend to use the disk space hence reducing the speed of the system. So Uninstall all the files and programs that are not in use. Don not delete them but go to START, then Control Panel and then Add or Remove programs option and Remove the desired program.
4) When downloading a ZIP file, when you expand it delete the original file when done.
Just try following the above ueful tips and Get going to use a Faster Pc.
Computers & Internet Logo
What is the max capacity of a Mac folder for archiving purposes on the hard drive?
According to HFS+ (the MacOS file system) limits since MacOS10.4, the maximum size of a file is almost 8EB (which is much bigger than any disk your likely to see even in the near future). Maximum number of files/folders in a file is up to 2.1billion, maximum number of files for a volume is almost 4.3billion. Also since MacOS10.6 you have the option of transparent compression, if you need to save space. Its still a good idea to leave at least 5% free (on any OS file system) to avoid congesting your system.
May 24, 2014 | Apple 13" MacBook Notebook Computer ...
Rar password recovery
rar password recovery 6.0 http://www.recoverlostpassword.com/products/rarpasswordrecovery.html
Mar 01, 2010 | Computers & Internet
how we can add extension in file type of open file dialod box
If you want to change the extension of an existing file type, then open any window, goto->tools-> folder options->view-> uncheck the option that says "hide extensions for known file types". Once you do that you'll get the filename with extension.You can necessarily change it accordingly.
Dec 13, 2008 | Computers & Internet
This copy of Windows did not pass genuine validation
1)Safe Mode
Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…  • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)  • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)  Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,  Select the view Tab and under the Hidden Files option, select Show hidden files and folders
2) Safe Mode Registry
Click on Start, Run and within the open dialog box type regedit and click OK.  • Within the Registry Editor navigate your self to  HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersi on\Winlogon\Notify\WGALOGON  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)  • After Exporting the folder, DELETE the WGALOGON folder  • After deleting close all applications and Restart your machine back to Normal Mode  After being prompt of a successful validation, Restart your Machine
Nov 29, 2007 | Microsoft Windows XP Professional With...
163 people viewed this tip
David Payne
David Payne
