Tip & How-To about Computers & Internet
Data Recovery (possible) from faulty hard drives
DAMAGED HARD DRIVE - DATA RECOVERY
Data recovery from faulty hard drives is difficult and can be costly. There is no guarentee that you can recover data from a faulty hard drive.
If the hard drive makes a clicking noise the the hard drive is dead.
First thing to try, is to remove the damaged hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an USB mass storage device (external hard drive) and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
Computers & Internet Logo
I need to recover information from my damaged Hitachi Life studio
If the hard drive is damaged then it is near impossible to recover your data without expert help.
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Check the Internet for companies near you that can service hard drives.
Nov 14, 2011 | Computers & Internet
formatting for Mac
What do you mean?Want to recover data from formatted hard drive?
Data Recovery Software can help.
Tenorshare Data Recovery is a professional data recovery program that can recover data from hard drive after deeply scanning your drive to look for lost data you accidentally deleted or formatted.
Get it from: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 30, 2011 | Iomega eGo Portable Hard drive 500 GB ...
I dropped the external Portable Hardrive (WD 500mg) and now it wont show any files that are on it. Is there any way to recover what is on the harddrive???? Jane I have tried plugging in and viewing but will only allow me to look at properties or eject ?
Hi Oscarmegs,
Your data on the hard drive are lost due to physical damage.But don't worry,you can recover data from hard drive with data recovery software.I have succeed with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage etc.
Anyway,download a trial version and scan your hard drive for free to preview whether your files can be recovered. http://www.any-data-recovery.com/index.htm
Jun 20, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
my external hard drive was damaged i wont recovery from hard drive.
Depending on the severity of the damage you have a couple of options.
1) Put the HDD inside a airtight bag and place in a freezer for at least 4 hours. Remove the HDD from freezer and see if it works. If it does start to work you will have a limited amount of time to recover the data.
2) Pay Data recovery company to recover the data
http://www.ontrackdatarecovery.com/
Mar 06, 2011 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Hard Drive recovery
Have you tried some data recovery software? You can use the Google search tool in this regard. .My Mac Book Pro hard drive has crashed and I'm in the process of replacing it. However, I had a lot of important data on that hard drive that he needs recovered. Then I found this data recovery software that recovers data from corrupt/bad hard drives. And fully supported for NTFS/FAT32 mac files. Mac Hard Drive File Recovery Recover Files from Formatted Mac Hard Drive
Dec 08, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
592 people viewed this tip
David Payne
David Payne
