Tip & How-To about Televison & Video
JSC sports
HI I need softcam for open channels JSC SPORSTS for star satX95 in NILL SAT or HOTBIRD thanks .thanks FIXYA sat
Televison & Video Logo
how to set up dreambox dm800 satellite receiver
The easiest way to start may be to find an image (firmware) backup and flash that to your box. Many have posted backups of their image that are set up and ready for use. Be sure to find the correct image for your box model.
If you want to set every thing up yourself from scratch, there are many things to explain. Better if you try first and then ask the specific questions about the problems.
Most things you set up from the menu, like Audio/Video settings, network, language, satellite dish setup etc. And some other things you might need some other tools and knowledge to do, like ftp and telnet.
For reading your smartcard for watching encryted channels you might need to download a softcam. On some firmwares this is easy enaugh from the menu, on others this is not so easy accessable.
Please just try, and then ask. Be sure to tell the exact problem and what image you are using.
One good source for images and more information is sat-universe.com
Oct 19, 2013 | Audio Players & Recorders
Process: Safari [5076] Path: /Applications/Safari.app/Contents/MacOS/Safari Identifier: com.apple.Safari Version: 4.0.2 (5530.19) Build Info: WebBrowser-55301900~3
Hi Dan. I'm not sure why you've sent all this here - it should go to Apple.
It looks very much like you have hit some bad Java code.
Jan 20, 2012 | Apple PowerMac G5 Dual Mac Desktop
North Star Dx440v
Hi and welcome to FixYa,
Enabling the 25.165MHz - 28.755MHz range of the radio would require modifications. Depending on the version of the DX440V, here or here. Incidentally, the Channel Chart is here.
Good luck and thank you for asking FixYa.
Nov 10, 2009 | Galaxy Radios DX-44V 40-Channels Base CB...
snow on screen and no picture on my DS35510
Offhand, if the previous system/connection works then we should leave that as it is. Coax-Sat Receiver-Coax-DVD Recorder-TV and TV should be Channel 3 (or 4).
On the new Sat Receiver, coax from LNB/Dish to Sat Receiver, yellow, red & white to TV. TV should be set to Video 1 or A/V or Video. There should be no snow, rather if no reception, it should be blue indicating video has muted in the absence of a good signal.
Good luck and Thank you for using FixYa.
Jan 04, 2009 | Sanyo DS35510 35" TV
270 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
