Tip & How-To about Computers & Internet
Heres a Few Tips to Speed up WIndows Vista...
1.Turn off Windows Search Indexing
Windows Vista search indexing is constantly reviewing files on your system to make their contents available for quick searching. This is handy, but can severely impact system performance.
To disable this constant indexing:
* Click Start then Computer
* Right Click the C: Drive
* On General Tab, Uncheck Index this drive for faster searching
* On the subsequent dialog box, Select Include subfolders and files
2. Turn off Remote Differential Compression
Remote Differential Compression measures the changes in files over a network to transfer them with minimal bandwidth rather than transferring an entire file that has previously been moved. By constantly checking for file changes, this service can hinder system performance.
To disable this service:
* Open Control Panel
* Switch to Classic View
* Select Program Features
* Choose Turn Windows features on and off
* Scroll down and uncheck Remote Differential Compression
3. Turn off Automatic Windows Defender Operation
Windows Defender real-time protection against malware continues to run despite having Automatic operation disabled.
To disable this feature:
* Select Windows Defender
* Choose Tools from the top menu
* Select Options
* Uncheck Auto Start at the bottom of the window
4. Turn off Automatic Disk Defragmentation
Windows Vista and its always-on defragment feature isn’t really that necessary and can cause system slow down. Just remember to run a defrag manually every week or so.
To disable this:
* Select the Tools Tab
* Uncheck Run on a schedule
5. Add a 2GB or higher USB Flash drive to take advantage of Windows Ready Boost (Additional Memory Cache)
Ready Boost is Microsoft’s name for using a USB thumb/flash drive to provide some quick access memory the operating system can use as extra RAM. The Ready Boost system can significantly improve system performance.
To set this up:
* Insert a USB Flash Drive (preferably 2GB or more)
* Right Click the USB Drive in My Computer
* Select the Ready Boost Tab
* Choose Use this device
* Select as much space as you can free up for RAM usage vs. Storage
6. Turn off Windows Hibernation
Windows hibernation background services can use a large amount of system resources. If you don’t use the Hibernate feature on a regular basis you may want to disable it to give Vista a performance boost.
To disable Hibernation:
* Select the Control Panel then Power Options
* Click Change Plan Settings
* Click on Change Advanced Power Settings
* Expand the Sleep selection
* Expand the Hibernate After selection
* Crank the selector down to zero
* Click Apply
7. Turn off System Restore
Analysis and restore point creation by Windows Vista can eat a fair amount of system resources. Disabling this service will obviously mean the system restore feature in Vista will not be available in the event of a system crash. Change this at your own risk.
* Control Panel>System
* Click System Protection on the left panel
* Uncheck the main system drive
* Agree to the confirmation
8. Disable User Access Control (UAC)
This much-loathed new Vista feature attempts to protect your system from malware infection by making you manually confirm a whole host of everyday user operations. While it doesn’t directly impact performance, it can be annoying and might be more hassle than good.
To disable User Access Control:
* Click Start then Control Panel
* Select User Accounts
* Select Turn User Account Control on or off
* Uncheck User Account Control Box
* Restart as recommended
9. Disable excess Windows Services that Auto-Launch at Startup
Just like Windows XP, Vista ships with all kinds of services enabled that load at startup and may never be used by most users.
To see what loads at startup and disable the ones you likely won’t be needing (they can always be started manually later):
* Select Administrative Tools
* Choose System Configuration
* Click the Services Tab
* You can safely deselect:
– Offline Files (unless you’re using Offline File Sync)
– Tablet PC Input Service (unless you have a tablet PC)
– Terminal Services
– Windows Search (If you have already disabled indexing)
– Fax (unless you’re using a fax modem)
10. Disable Excess Windows Features
Windows ships with other features that are listed separately in the Vista operating system from the startup services.
You can view and disable these features by:
* Clicking Start then Control Panel
* On the left panel, select Turn Windows Features on or off
– Indexing Service
– Remote Differential Compression
– Tablet PC Optional Components
– Windows DFS Replication Service
– Windows Fax & Scan (unless you use a modem for faxing)
– Windows Meeting Space (unless you use the Live Meeting Service)
Computers & Internet Logo
How can I reinstal Windows Search and Windows Security Centre
Install Windows Security Center
Open Internet Explorer and navigate to the Microsoft Windows Update website.
Click the "Express" button on the main page to have your computer checked for important updates to be installed.
Since Windows Security Center is not installed, it will be detected and installed within the update.
Search the list of updates that will be installed on your Computer and deselect any options besides Windows Security Center that you don't want installed at this time.
Click "Install Updates" to begin the installation process.
Set your computer up for Automatic Updates to keep your computer up to date.
You can do so by clicking "Start" followed by "Control Panel."
Click "Automatic Updates" and select the recommended option.
Click "Apply" followed by "OK" to save the changes and exit the window.
Install Windows Security Center in Windows Vista
Click the "Start" button followed by "All Programs." Scroll through the list and select "Windows Update" from the available options. You can also type "Windows Update" in the search field followed by pressing "Enter" to access it immediately.
Click the "Change Settings" button in the left window pane.
Select the radio button next to "Automatically download and install updates."
Click "OK" when you have finished. Windows will begin to scan your computer and download the necessary updates, one of which will be Windows Security Center if it isn't available on your computer already. When the updates have finished installing, a bubble will pop up in your system tray telling you new updates have installed and your computer needs to be restarted.
Restart your computer and once you log back on to Windows, Security Center will be available. You can access it by clicking the "Start" button and typing "Windows Security Center" in the search field. It will also be available in the "All Programs" software list.
Reinstall Windows Search
If for some reason you've lost Windows Search from your computer, it is possible to reinstall it.
Reinstalling Windows Search will improve the performance and stability of your computer system's indexer.
It will allow you to sort and group results in Windows Explorer more quickly, and will improve the indexing of your online email.
It expands your system's ability to do fast remote queries of file shares, including on Windows XP and Server 2003.
It automatically indexes shared folders and contains improvements in previews for earlier supported operating systems (Windows Server 2003 and Windows XP).
When you type a search term into Windows Search, the results appear quickly.
This is also true for information from emails and their attachments.
Download and install Windows Search on your computer.
http://www.microsoft.com/windows/products/winfamily/desktopsearch/choose/windowssearch4.mspx?tab=Install%20It
Click on the appropriate link for your version of Windows.
Click "Open" to download the file if you use Vista.
Click "Save" to download the file if you use Windows XP.
Click on "Run" to install Windows Search on your computer.
Follow the prompts to complete Windows Search installation.
Restart your computer.
Windows Search will be available in the Start menu if you use Vista.
If your operating system is Windows XP, use the Deskbar for quick and easy search access to indexed content on your PC or the network.
Personalize Windows Search for an optimal search experience .
Add-ins let you index Outlook saved email, Microsoft networks, Internet Explorer history and Lotus Notes.
Hope this helps
Nov 03, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Indexing service doesn't work.
IF you have a full genuine copy of windows, check the microsooft knowledge base.
IF you have a cracked/copied version, it may be of an earlier build, not the final version. This may be the problem you have.
THis may also be a virus/malware infection. Scan for both in safe mode
Jul 21, 2010 | Microsoft Windows Vista Ultimate Edition
constant hard drive noise on j2489
Are you using Vista? If so that's your problem, Vista is constantly scanning your hard disk for indexing. To turn it off follow this link: http://4sysops.com/archives/how-to-disable-vista%E2%80%99s-desktop-search-indexing-windows-search/ but bear in mind that search etc will be much slower, and some things in Vista may not work the way they're supposed to as it is now an integral part of the OS.
Aug 04, 2009 | Computers & Internet
176 people viewed this tip
David Payne
David Payne
