Tip & How-To about Hand Tools
Proper use of a torque wrench
A torque wrench is a powerful yet sensitive piece of equipment. When used correctly it can mean the difference between a job well done and job gone wrong.
Proper torquing is easy as long as you remember a few simple rules. One, never use a toque wrench to loosen bolts. Two, never use any object to hit or pry on a torque wrench, These things will result in damage and or improper readings.
The proper method for torquing is to be ready to apply the correct amount of force. Anything over 60-70 lbs may be hard for some people. Get assistance if needed. Not applying the correct pressure (stopping mid pull) may bind the wrench. Use a steady pull until the click is heard or felt, never tug or bounce the wrench.
Following these steps will help insure a proper assembly no matter what it is. Work safe and work smart. Happy building
Hand Tools Logo
need to replace the head gasget
Big job, good luck. You need the workshop manual and you need a good quality torque wrench.
May 14, 2016 | Cars & Trucks
Head bolts setting for megane 2.0 l 16v. Ide f5r engine anybody please. In neuton metre not angle please. But angle will do. Please
you could possibly get the tensions by going google and typing in--- head tension s for renault megane 2.0 l engine
torque settings in ft/lbs or newton meters is a by gone thing as the better method of stretching the bolts is to do it by angles
by using a torque wrench the bolt stretch ( tension) has variables like bolt thread finish, thread lubrication, bolts bottoming out from gunk/oil in the hole , uncalibrated tension wrenches , all of which means that not all head studs are pulled down to the correct stretch
By using angles , the head tension becomes uniform
Sep 06, 2015 | Cars & Trucks
Torque specs on a 1987 Nissan 300 zx 2+2 plenum
If you are referring the the collector the specs are:
Collector cover: 4.3 - 5.8 ft lbs
Collector: 13-16 ft lbs
You should use a torque wrench that is sensitive at low torques. I bought an "inch pound" torque wrench for delicate items like injectors and just convert the foot pounds to inch pounds.
Mar 03, 2015 | 1987 Nissan 300ZX
the cylinder head gasket has blown. how do i change it and do i need a torque wrench?
This is one of those times I recommend you load it up and take it to a Honda shop. There may be more than a blown head gasket. And by the fact that you ask if you need a torque wrench we can tell you are not used to jobs of this nature. You most definitely need a torque wrench, torquing a head is one of the most important things about a bike. Spend the money and know it is done right.
Nov 03, 2009 | Honda XR 125 L Motorcycles
Head replacement
You can do it. You will need a good set of basic hand tools. The only special tool you should need is a torque wrench. If you have never done this, I suggest buying a manual
Jul 04, 2009 | 2002 Buick Rendezvous
317 people viewed this tip
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
