Tip & How-To about Garden
Lawn Mower Doesn't Start after Being Garaged
Greetings,
You find the weather getting nice and warm and see the new blades of green grass poking out from the ground after a hard long and cold winter.
Just then it strikes you, the lawn mower must come out of what we call, "moth balls", because very soon you will be needing it to cut the grass.So off you go to the garage or shed and pull out the mower that was put away at the end of last summer.
To your dismay after checking and filling the gas tank with regular gas and checking it's oil level, you prime the carburator and make the first attempt to pull that chord to start it.
No luck, so you pull it at least twenty more times priming the primer ball with your finger etc, it still wont start whether it be a self propelled Toro or Sears Craftsmen, it does not want to start, what do you do?
Well at first you think perhaps i'll take it to the lawn mower repair shop, but then you think, man the last time I brought my mower over to them it cost me more to fix it then it did to buy a new one.
I have been there and done all that folks and that is why i am writing this helpful tip for you in hopes to keep the money in your pocket rather then in someone elses.
First step you need to do is buy a can of starting fluid at any auto parts store, be certain you have on hand fresh 87 octane fuel at least three gallons for your lawn cutting experience throughout the summer months, a pair of pliers and a straight bladed and a phillips head(cross) screw driver approx 6" long and a can of carburator cleaner.
next tip, you remove the lawn mowers air filter most just twist and turn off(the ones that are shaped like a round mesh 2" diameter dowel), or the type that require a screw to be turned off to remove the flat shaped filter cover either one, once off spray a bit of starter fluid in the carb. opening and try to start it.
If itb starts run the mower and use it until all the fuel level drops then add more.
the mower should be good to use.
If the starting fluid doesn't start the mower, 99.9% of the time you have old stale fuel, reach under the carburator and locate the 3/8" black fuel line and unclip it letting the gas drain from the system into a flat pan, most times you need to remove the air filter cover to help gain access to the fuel line, next very carefully abserve the very bottom of the carburator, notice a round metalic bowl attached to its base by a nut approx. 3/8" or 7/16" hex size? Mark the outside edge of the bowl because the next step is you are going to remove that bolt holding the bowl and drain out the fuel and possible dirt that is lodged in it, carefully spray a stream of carb. cleaner into any of the tiny openings in the carb doing it gently as not to disturb any operation parts such as the float and the needle and seat that can come apart if you are not careful holding it. Be aware to have protective eye wear, also being careful not to disturb the rubber "o ring" gasket that seals the bowl at the top.
Put everything back together and refill the tank with fresh fuel, opay attentetion to the bowl marking you put on it before you removed it, should face out and centered, so you dont install it on the wrong position.
Fuel line tigh and clamped,air filter housing on after a little spray starting fluid, primer the ball at least five pushes, pull the cord, Walla, it runs like new!!
Happy Lawn Mowing!!
Garden Logo
the blades don't push the grass to the bags
the blades are the wrong ones for throwing grass clippings
they have to have turned up edge to generate an air flow out of the chute to the bag
talk with the mower shop for the correct blades
Sep 09, 2017 | John Deere Garden
cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
Nov 21, 2015 | Cars & Trucks
car kills in warm weather but not cold
your engine might be overheating thats why it stops on warm weather. Check all the ventillation and make some engine check too..have a nice day
Mar 21, 2012 | 2003 Ford Focus
Why does the grass turn green when spring time comes then?
During the winter and fall months, rain falls less, sun shines less, and the air is much colder. Grass gets its green color from Photosynthetic cells in blades. The more sun and nutrients the grass see the healthier it grows. As the grass sees less sun, water, and is frozen from time to time, its internal processes slow down and many cells die or become dormant. As the rain begins to fall again in the spring and the sun shines longer and stronger it becomes much easier for the blades to transfer nutrients to the entire blade and will become a more full and vibrant green again. you can see this process in action when grass is cut too short in the spring or summer months. The grass will look almost yellow because exposed grass is usually "sun blocked" by the grass just inches higher. Yet in a day or so , you will see the grass turning green again from the botton up but the tips of the grass will remain white and dead until the grass grows and the tips fall off to form the all to familiar grass blade "D
HOPE THIS EXCEEDED YOUR EXPECTATIONS :D
May 09, 2011 | Nintendo Super NES Console
159 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
