Tip & How-To about Computers & Internet
Easy way to burn WMV video to DVD and play on a DVD player
One of the most popular video formats used with computers and found on the web is WMV. WMV is wide compatibility with Windows PCs. it short for Windows Media Video. And it is the name of the video encoder that was created by software giant Microsoft. The advantage of WMV is that Good compression and quality. WMV movies are played with third party media player programs such as "Windows Media Player, "RealPlayer" and "VLC player". A lot of people saved WMV clips onto compute and want to make WMV to DVD for playback on a DVD player watch videos on TV screen.
DVD ( Digital Video Disc ) is an optical data storage device which can hold large capacities of digital data like high quality video and movies. A VOB ( DVD Video Object or Versioned Object Base ) file is a container format for DVD video files. An explanation of VOB files is beyond the scope of this article, but a study of the software part of the DVD format is essentially a study of the VOB container file format. With CD’s or Compact Disc’s becoming virtually obsolete with the emergence of high capacity storage HD DVD’s and Blueray disc’s, more and more video editing tools are geared to conversion between these two highly popular media formats, WMV to DVD.
How to convert WMV file to DVD?
Before we go to detail steps, there are some Pre Requirements: A blank DVD disk (DVD +R, DVD-R, DVD+RW or DVD-RW), rewritable DVD-ROM, A WMV to DVD Converter. Most DVD burning software can easily burn WMV files to a DVD as data. Here we use Daniusoft DVD creator. It can burn WMV Video files to DVD directly.
Step1. Import WMV videos
The first step is to import WMV files that needs to be burned onto a DVD may reside on the local hard drive or on an external device such as iPod. If it is not on your computer, copy the WMV file onto the local hard drive first and then Select/drag the WMV file into the main interface of D DVD creator. You could check the video size on the measure bar on the bottom. Make sure the space doesn't exceed the total DVD capacity.
Step 2. DVD menu making
Click "Menu Template" to create DVD menu. There are different styles of built-in templates, frames and buttons for your choice. To apply a template, frame or button, you can just double click it. You can even add text, background music and background image to customize the menu.
Previewing WMV video
Just for make sure everything goes as your plan you could have a video preview before burning it to DVD.
Step 3. Convert WMV to DVD
Now you can burn WMV to DVD disk. Go to set TV Standard (PAL/NTSC) on "Setting" option and output Aspect Ratio (4:3/16:9) on "DVD setting bar". Click "Burn" and then select your DVD drive (if you have more than one DVD drive on PC) and Click "Start" to burn your project.
Tips: The volume of DVD use is shown on the bottom side. You can select DVD type of "D5" or "D9". If the video size is exceed the DVD capability you can reduce it by setting output quality. E.g. select "high quality" instead of "Best performance".
That it, with Daniusoft DVD Creator, you can convert WMV to DVD and even make your own DVD menu in 3 steps. And the application also can burn other common files like MKV WMV M2TS MPEG AVI FLV MOV, etc to DVD and fully compatible with Windows 7 (DVD Creator MAC version is also available). Now, just enjoy watching your own made WMV movie on home DVD player.
Related guides:
How to convert and burn MOV to DVD?
How to convert and Burn MKV to DVD for playback on DVD Player?
Computers & Internet Logo
How to convert a WMV file into an MP4?
There are many converters out there. I would suggest using VLC converter because it supports many formats and there are Mac and Windows versions. Go to http://www.videolan.org/ to get this.
Mar 09, 2012 | Computers & Internet
Tip about converting WMV to MOV on MAC without iMovie
As the problem of conversion, i think Video Download Studio can help you very well. with easy and simple user interface supporting a wide range of video formats including AVI, MPEG, MP4, 3GP, WMV, MP3, FLV, MOV, WAV and more. get a free trial from http://www.downloadvideos-convert.com/download-videos-music hope it can help you more or less!
Jul 02, 2010 | Computers & Internet
limewire pro 5.5.14 license key
Get it from Your Product Service Care Or Search it through Online.
Oct 04, 2010 | Computers & Internet
wat type of video file type do sansa mp3 players use? i cant seem to find a file type to successfully play videos on it
The new SanDisk e260 designed to work seamlessly with a wide range of popular music formats such as MP3 and Windows Media Audio (WMA) in both unprotected and protected files (such as those WMA files purchased from music stores). It also supports the newest music subscription services found at Rhapsody to Go and others
  • Music Playback Formats: MP3, WAV, WMA
  • Photo formats: BMP, JPEG, TIFF, GIF
  • Video Formats: AVI, MPEG4, WMV, QuickTime, MPEG2, ASF
  • You can go to this website and download a free format converter.
  • http://www.formatoz.com/
  • Good Luck, I hope this helps
  • Nov 30, 2009 | SanDisk Sansa e260 MP3 Player
    337 people viewed this tip
    David Payne
    David Payne
