Tip & How-To about Computers & Internet
Slow boot of the computer
If your computer is booting very slow and your operating system is XP / VISTA / WIN 7 dont get frustated//
here is the quick solution
1) xp computer---click start/ run/ type msconfig/ ok/
system configuration window will open//
goto startup / hit the tab disable all at the bottom// apply//
go to services and at the bottom put the check on the box which says " hide all microsoft services" then click ok or close to close the system configuration window and restart the computer and it will boot very fast .
when the computer boots up you will get the window of system configuration and at the bottom put the check on the box which says "do not show this msg again".
note** vista and win 7 user will have to follow the same steps.. just type the command " msconfig" in the start seargh which appears at the bottom when you click the start button.
Computers & Internet Logo
dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
I have installed Win 7 ultimate and after i have installed win xp sp3 in different drive. But now at booting the computer dosent show the operating system choice but instead win xp starts as the default operating system.
When installing different versions of Windows, you must start with the oldest system first.
1. Booting from XP disc, create 2 partitions before installing and install XP to one of them.
2. After XP is complete, install W7 to second partition and after it is complete you will be given the OS System Boot choice at Start Up.
Regards,
Selk
Mar 27, 2011 | Computers & Internet
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
i want to install xp over vista in hp laptop
do you want to replace vista or run double OS's, in other words you would be prompted to select either or operating system to use prior to loading screen.
Dec 13, 2007 | Microsoft Windows Vista Ultimate Edition
248 people viewed this tip
David Payne
David Payne
