Tip & How-To about Universal Remote Control DIRECTV Universal Remote Control
DirecTV Remote Control Code Entry
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
Televison & Video Logo
what is the coad to set a rca remote no precision tv
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Sep 15, 2010 | RCA DIRECTV Satellite Remote Control
I need codes for an RCA remote 240983 to attach to my Zenith TV
<span style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 22pt; mso-bidi-font-size: 10.0pt">RCA</span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">HI,</span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">Direct Code Entry:</span></b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"></span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 11pt"><br /><b><span style="FONT-FAMILY: 'Arial','sans-serif'">Find the code your device.</span></b> </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />1. Press and hold "CODE SEARCH". </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed. </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />3. Enter the 3-digit code number. </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />4. Release "CODE SEARCH". </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.</span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br /><b><span style="FONT-FAMILY: 'Arial','sans-serif'">follow the below steps to set remote without codes</span></b></span><br /> <br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">Code Search:</span></b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"></span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">1. Turn on the device you wish to control. </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />2. Press and hold "CODE SEARCH". </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed. </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />4. Release "CODE SEARCH". </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />5. Press ON/OFF repeatedly until the device turns off. </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />6. When the device shuts off press and release ENTER. </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">7. Try using the remote. If it does not function repeat steps 1 through 6</span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <b style="mso-bidi-font-weight: normal"><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 11pt">To Get The Code Please Go To Below Website</span></b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt">:</span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"> </span><br /> <a href="http://www.rcaaccessories.com/remotefinder/" target="_blank"><span style="FONT-FAMILY: 'Trebuchet MS','sans-serif'; FONT-SIZE: 10pt; mso-bidi-font-family: Arial">http://www.rcaaccessories.com/remotefinder/</span></a><span class="MsoHyperlink"><span style="COLOR: black"></span></span><br /> <span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: windowtext; FONT-SIZE: 10pt"><span style="TEXT-DECORATION: none"></span></span></span><br /> <span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><u>You need to select the following information from the drop down list</u></span></span><br /> <span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><span style="TEXT-DECORATION: none"></span></span></span><br /> <span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><u>1.Model of the remote</u></span></span><br /> <span class="MsoHyperlink"><span style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: black; FONT-SIZE: 10pt"><u>2.Type of device to which you want to program(TV/DVD/VCR)</u></span></span><br /> <span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 10pt"><br />Thank you </span>
Aug 30, 2010 | RCA DIRECTV Satellite Remote Control
direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
DirecTV Remote Control Onscreen Setup
May 13, 2010 | Universal Remote Control DIRECTV Universal...
2,742 people viewed this tip
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
