Tip & How-To about Computers & Internet
Power Efficiency Report In Windows 7
If you have a laptop, you can use the efficiency calculator to get Windows 7 to generate loads of useful information about its power consumption. Used in the right way, this can help you make huge gains in terms of battery life and performance. To do this you must open a command prompt as an administrator by typing 'cmd' in Start Search, and when the cmd icon appears, right-click it and choose Run as administrator.
Then at the command line, just type in 'powercfg -energy' (without quotes) and hit Return, and Windows 7 will scan your system looking for ways to improve power efficiency. It will then publish the results in an HTML file, usually in the System32 folder. Just follow the path it gives you to find your report.
Computers & Internet Logo
how much output can i get from northstar 5500 ppg generator
there are two things in generator out put
one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
Jun 30, 2012 | Northstar Generator 9 Hp, 5500 Watt,...
camera dsp error
Welcome to FixYa,
DSP means Digital Signal Processor and this is the part in your phone responsible for processing digital imaging.
The amount of image data gathered by camera nodes in WMSNs is very large. They need to be compressed before transmission. JPEG2000 is the image compression standard which has many advantages, such as high compression efficiency and high image fidelity. However, its high computational complexity makes it a big problem when using it in WMSNs. To satisfy the low-power and high image quality requirements of WMSNs, studies shows the low-power JPEG2000 realization on DSP-based camera node.Fixed-point LS9/7 wavelet is used instead of CDF9/7 wavelet to decrease the complexity of computation. embedded block coding is improved for high efficient DSP parallel processing.
Some experiments results show that the improved JPEG2000 leads to a great reduction in implementation time, and hence saves energy consumption of camera nodes.
But sometimes, in my experience, pulling out the battery and try to insert it again, will solved the issue.
I hope this information help you to resolve yuor issue.
Thank You for using FixYa.
Mar 04, 2011 | Cameras
natural gas consumption chart 4 1m gas power generator waukesha
NG consumption will be specific to the generator itself. Your best bet would be to consult the user manual, or at the very least, post the model #.
A very loose rule of thumb is that if your generator consumes 1 gallon of fuel at a certain load, it will consume 100CCF (aka 1 Therm) of NG, or 1 gallon of propane.
The numbers that you are stating are WAY above Stanly power generators, are in a class that is considered to be Commerical Equipment.
Jun 21, 2010 | Stanley Electrical Supplies
fuel efficiency
Hi, Fuel comsumstion is based on ,speed,load inside the car,tire size, tire air presure,road condition,and driving habits....
Aug 17, 2008 | 2005 Chevrolet Aveo
126 people viewed this tip
David Payne
David Payne
