Tip & How-To about Computers & Internet
Photo editing tip in WIndows 7
You can easily preview the photos in the windows explorer while you are actually working on it. You just have to press a key combination of ALT + P and a photo preview will appear on the right side of the screen.
Computers & Internet Logo
how do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Please see attached photo, this is what's
what are you trying to do ?
a bit more information might be able to help you.
IE: what are you doing when this (pop up) occurs ?
and why are striking the F1 or F2 keys ?
Computer keyboards contain keys that, when pressed on their own or in conjunction with another key, provide shortcuts to performing functions, saving time and keystrokes.
On most keyboards, these are the function, or "F," keys that run along the top of the keyboard. "F1" and "F2" are members of this group.
F1 Function Key
Pressing the "F1" function key while you are in an application will bring up the application's help file.
Pressing it when you are not in Windows Explorer or on the desktop produces the "Windows Help" file.
If you are in an application and press the "F1" button along with the Windows button, you will get the "Windows Help" file.
F1 Function Key Combined With Other Keys
"F1" can be pressed with other keys to gain a variety of results and functions.
Press "F1" and the "Shift" key to start context sensitive help, or help for the application.
Use the "F1" key with "Alt" to go to the next field in an application.
Press "F1," "Shift" and "Alt" at the same time to return to the previous field in an application.
To display the Microsoft system information, press "Ctrl," "Alt" and "F1" at the same time.
F2 Function Key Clicking on an icon on your desktop and pressing the "F2" function key will put the icon into rename mode in the same way as right-clicking on the icon and scrolling to "Rename."
F2 Function Key Combined With Other Keys
"F2" when pressed with other keys combines functions commonly found in the application "File" and "Edit" menus.
To copy selected text, highlight the text and press "Shift" with "F2."
To view a print preview of a document, press "Ctrl" with "F2" when in a document.
To save a document, press "Alt," "Shift" and "F2 together when in the application.
To choose the open file command, press "Ctrl," "Alt" and "F2."
Apr 22, 2013 | Computers & Internet
hi i have the asus n53jg laptop. absolutly amazing laptop cant nock it i just have a little problem that i want to get sorted see the laptops function keys that run along the top have shortcuts on them like f10 and others how do i get them to work because i dont get anything when i press them.
The function keys that you have works alone and in combinations. You can press and hold Fn key then tap on any of those keys to get the short cuts. You can also press and hold Alt key and any of those to get another short cut. It actually depends on what you want to do.
For example:
Using single key:
F5 - it will refresh a window
F11 - try it in internet explorer to see the result
Using Combination:
Alt + F4 - it will close an open window
Fn + F3 - it will lock or disable your touchpad
I hope I understood your concern and helped. Goodluck
Jul 17, 2011 | ASUS Computers & Internet
Curser turns to circle with black line through it
Hello, Try changing the cursor's color with these detailed instructions:
No. Mouse actions Keyboard actions 1 To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
To open the Ease of Access Center, press:
  • Windows logo key winkey.gif+U.
2 Under Explore all settings, select:
  • Make the mouse easier to use.
  • Make the mouse easier to use by pressing TAB, then ENTER.
3 Under Mouse pointers:
  • Select a cursor and pointer combination.
  • Select Save.
Under Mouse pointers, select a cursor/pointer combination by pressing:
  • ALT+R for Regular White
  • ALT+U for Regular Black
  • ALT+G for Regular Inverting
  • ALT+L for Large White
  • ALT+B for Large Black
  • ALT+I for Large Inverting
  • ALT+X for Extra Large White
  • ALT+K for Extra Large Black
  • ALT+N for Extra Large Inverting
  • Select Save by pressing ALT+S.
May 06, 2011 | Compaq Computers & Internet
Shortcut
To create a folder with shortcut key combination in windows explorer press Alt (and while it is pressed) press F W F
Oct 09, 2007 | Microsoft Windows XP Professional With...
175 people viewed this tip
David Payne
David Payne
