Tip & How-To about Nintendo Wii Console
Wii problems
Hi there
Thanks for using Fixya.com
If you have wii problems, like disk read error's,blank screens, stuck disks, sync problems or anything, your best solution is to use a wii repair guide
you can pick up a wii repair guide for less than $20 and there very handy to have. you will not need to send your console away, just consult your guide and do the fix.
good wii repair guides will be accompanied with a website that will have forums to discuss problems and get help of people who have fixed there own wii's
Have a look at this website Everything Wii the guide on here is the one i use its very good.
Remember a problem shared is a problem halved.
Nintendo Wii Console Logo
i have the same problem i try two diferent disc y nothing happen. same error . i dont think is my wii console.
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. I like to use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, which pack more info onto a disk (Super Smash Bros. Brawl and Metroid Prime use dual layer discs). If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. If all fails and still you Wii cant read any disk it only means that the Wii is malfunctioning.
Thanks for Reading. Thanks for using Fixya.
Feb 06, 2011 | Nintendo Super Smash Bros. Brawl for Wii
nintendo wii message reads: error occured remove disc turn off console check operations manual for information! on 2 new games
Some older Wii units also have trouble with Dual Layer Discs, which pack more info onto a disk like Super Smash Bros. Brawl and Metroid Prime. If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. the other resolution for this is to change the laser on the system but it will cost you for that. Try to clean the lens first it might read the new disk.
Jan 31, 2011 | Nintendo Wii Console
My wii says its unable to read disk on all games including new ones what can i do
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii.Since that your Wii is having a problem reading al disk there's might be a problem with it. Some older Wii units also have trouble with dual layer discs, which pack more info onto a disk .If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. If still having an issue better call Nintendo for further Support. You might have a Bad lens on your Wii.
Thanks for reading. Thanks for using Fixya.
Jan 31, 2011 | Video Game Consoles & Games
my wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Jan 28, 2011 | Video Game Consoles & Games
Stuck a disk in Wii while 1 game inside already
the issue probably requires a new part ordered might i make a suggestion trying
REPLACEMENT DVD-ROM DRIVE
http://www.gaminggenerations.com/store/replacement-drive-p-2020.html
The part will cost you about 50 bucks but as this is a diy service this will be your best bet at fixing the problem, if the warranty is expired go for it.
we are here if you need our help. and if you need more expert assistance please try the paid version of fixya. if this is not informative enough. 3 bucks usually is all it takes to get a very accurate diagram as well as detailed instructions and assistance. good luck with the wii and thanks for using the fixya service.
Sep 20, 2009 | Nintendo Wii Console
707 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
