Tip & How-To about Cell Phones
To Reset Your Nokia N73
Just dial *#7370# .....it will reset your phone......remember this will even remove the contacts stored in your phone memory.....so remember to take a BACK-UP OF YOUR CONTACTS BEFORE YOU DIAL THIS.......I think it will help some one....and never mind to share your comments please......
Yours Lovingly,,,
Shikhz...
Cell Phones Logo
i want to format my nokia 1112
go-to the phone menu and select (setting)then go to the option of (Re-store factory setting) the phone will ask for Password type 12345 then press ok .your phone will be reset .
OR:
the code is 12345 or 00000
OR:
for soft format dial *#7780# or *#7370# which restores the factory settinngs
but if you format the whole phone memory then follow the procedure below ( remember one things this will deletes all your mesages, all contacts, photos, notes etc in the phone memory.. your phone is like a new phone
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
thank you
Thanks
Oct 29, 2010 | Nokia 1112 Cellular Phone
how to format nokia 6600,bcoz its to slow..even memory card already remove....
Primary Method:-----------------------------------------------------------------------------
  • Turn your device off.
  • Remove SIM card and MMC card (actually, you do not need to remove these, but after format remember to format memory card and reboot phone).
  • Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad Together.
  • Turn your device on while you are pressing the three buttons.
  • You should now see "Formatting .." on the Screen! Leave the buttons now.
Alternate Method:---------------------------------------------------------------------------
  • You can remove the mmc but keep the sim card and restart your phone.
  • Then press the keys *#7378#
  • The phone would ask a confirmation.
  • Select yes.
  • Then it will ask for a code.
  • The code is 12345 (the default).
  •  Your phone will restart with all the phone memory formatted.
Tips:-----------------------------------------------------------------------------------------------
  • You can also use some programs to format the device for you
  • The format will not include the MMC Card, only the device (C Drive)...
  • The above methods aren't always easy. You can do the format using this simple key combination *#7370# and the phone will prompt you to enter the phone lock code which is 12345 by default.
  • Also remember that you can reset your phone but not loose any of your personal files (I.E restore the settings that came when you bought the phone while keeping contacts etc)
Warnings:---------------------------------------------------------------------------------------
  • Don't apply these steps if you are not sure what you are doing.
  • Make sure you have enough battery power before beginning this procedure.
  • Formatting will erase all your contacts/messages, so make a backup of your phone before formatting.
  • If have MMC-card make a backup on MMC-store file !
Thank you Sir, I hope I was helpful to you. Please rate me. Ok, Have a nice day.
Sep 18, 2009 | Nokia 6600
Dialling problem in Nokia N 73 mobile
remove memory card / format the phone with*#7370#12345(or the lock code) /try it if it good the memory card is having a virus so you can format it or scan it on th pc
May 10, 2009 | Nokia N73 Cellular Phone
hi Sonubaath
press *# 7370 # your phone will format.....
Jul 30, 2008 | Nokia 3230 Cellular Phone
Phone memory protected
Under Menu>Contacts>Settings.... Under memory in use, change it to phone and SIM. It will probably ask for a security code which should be in your book, if you haven't changed it, its something like 0000 or 12345 or similar. then you should be able to copy all to the simcard.
Good Luck esm_taher@yahoo.com
Jan 14, 2008 | Nokia 7370 Cellular Phone
156 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
