Tip & How-To about Computers & Internet
How to change icon of any file
Right click on the folder which you want to change icon and select properties. Then go to customize tab. Under folder icon click on change icon and select the icon you want to change.You can also browse icons of your folder.
Computers & Internet Logo
vice city 004dfb50
Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Apr 30, 2013 | Computers & Internet
USB flash drive problems
also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
Click permissions
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7
Jan 08, 2013 | Computers & Internet
icon changing to generic windows
Steps for Changing a System Icon:
BEFORE YOU BEGIN!
Right-Click your desktop and choose "Properties". Then follow the steps below.
1. Click on the "desktop" tab at the top of the Display Properties window.
2. Then click the "Customize Desktop" button.
3. A Desktop Items window will open. Choose the "General" tab.
4. From the dsplay of system icons, click on the icon you want to change making sure it's highlighted.
5. Click on the "Change Icons" button. This will allow you to browse your computer for the icon you want to use as a replacement for your System Icon. (remember to click "OK" and "Apply Changes" once you have chosen a new icon).
Jan 30, 2010 | Microsoft Windows Vista Ultimate Edition
Icon background in Windows XP 2
It looks like a custom view for a music folder. Try right-clicking on the folder in Windows Explorer, then select the 3rd tab, "Customize", and change your folder type.
Jan 27, 2010 | Microsoft Windows XP Professional SP2
wd passport file customizing
If you open the Computer directory and identify the drive letter for the WD Passport drive, right-click on the drive folder and select properties. The properties tool for the drive will open showing several tabs. Select the Customize tab and you will see a heading for "use this folder type as a template" with a drop down menu. Here you can select different categories for the folder and apply it to subdirectories also by checking the box below. This should give the folders more of a vista look! If you want to personalize further and add your own images to the folder icons you can also do this here. If you don't select the apply to subdirectories option you can manually apply different styles to different folders in subdirectories. If you don't like the way things have turned out you can also restore the default settings.
Hope this answers your question.
Have fun
Dec 06, 2008 | Western Digital Computers & Internet
240 people viewed this tip
David Payne
David Payne
