Tip & How-To about Measuring Tools & Sensors
How to operate a stud finder
Hi There,
Sometimes the LED type readouts on stud finders aren't as intuitive as one would hope. This will help clear up what you are seeing.
There are usually four LED's and a button on the device. The LED's indicate an increased density in wall, but increased from what? Each time the unit is used it needs to go through a short calibration to get a frame of reference.
This is the procedure:
  • Place the unit flat against the wall.
  • Press and hold the button.
  • The LED will come on for a second or two then go out.
  • Slowly move the unit laterally until the LEDs come on again. You're getting near a stud.
  • When they top out (all four lit), that is the beginning of the stud. Mark it.
  • When they start to go back down, that is the end of the stud. Mark there too. The stud should be between the marks.
That's about it.
It beats knocking on the wall or drilling test holes.
Best regards
Mike
Measuring Tools & Sensors Logo
how to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Aug 04, 2014 | Stanley 77-720 Stud Sensor 200
I need help finding a stub behind drywall
The stud finders are not expensive but you can sometimes use a magnet to find the nails. Also you might try shining a flashlight across the wall. The putty put over the nails will sometimes show up. Last resort is to tap on the wall and try and hear the areas that have support under them.
Jan 26, 2013 | Drywall
need drivers asus p5gc-mx
http://download.cnet.com/asus-a7v133-bios/3000-2098_4-10163294.html
http://download.cnet.com/asus-v7100-series-display/3000-2108_4-10163299.html
http://download.cnet.com/asus-a7v8x-bios/3000-2098_4-10163301.html
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise) exclusions - / you might have try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
hope this helps
Sep 08, 2011 | ASUS P5GC-MX/1333 Motherboard
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
1,868 people viewed this tip
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
