If a disc gets stuck in the recorder, there a few steps to try before the problem becomes service-related:
1. Power the unit off (so it shows the clock), then simply press the Open/Close button. The unit should power on and attempt to eject the disc.
2. If the above doesn't work - power it off again, then press and hold the STOP and CH UP button on the recorder itself together and hold them down until the unit powers up. This is called a force eject. If this doesn't work (usually if it's not going to work the recorder will simply come on momentarily then loop back into "bye" and go back to the clock), there is one last method to try.
3. Unplug the unit for 30 seconds. Press and hold the same buttons as above as you plug it in. After it performs the self-check "ooooo" across the screen it should do the force eject. If not, the unit requires service to be repaired and possibly the drive replaced.
Did you find this Tip Helpful?
Can you Help with these DVD Players problems?
Panasonic DMR-EZ47V DVD Recorder / VCR...
i didnt know that you could set the time on the dmr-ez47v...
I tried to use the product in Europe,so the remote control...
Error code "00 00 00" repeats on unit display,...
All of a sudden my programs and VCR tapes are blocked....
how can i set the time on it please?
Sponsored Links
