Tip & How-To about Office Equipment & Supplies
How can you clear a cartige ink jam
You can clear a cartige ink problem if it is not printing by rubbing metal part of the cartige by a eraser aur by polishing it by hot water
no print even on test print cartridges say the ink is about a quater left in both
Cartridge might have dried up, remove and use a Qtip with nail polish remover and rub over bottom part of cartridge where lines of micro sized holes can be seen, usually there is some ink dried there. Ink is water based until dry.
Oct 21, 2010 | Lexmark 1100 Color JetPrinter InkJet
yellow ink is not printing properly
i think your cartige yellow ink had finished or dried up what u can do is refill yellow ink or dip cartige into hot water.... and clean it nicely it works
May 20, 2009 | Canon Pixma iP4500 InkJet Printer
Not printing red ink clearly
i think problem could be solved
take out the cartige and the cartige holder , spray them with glass cleaning solution and replace them back
Nov 11, 2007 | Epson Stylus Photo 900 InkJet Printer
Not Printing
the problem you all have could be from the ink cartige or from the ink cartige holder , take out the cartige from the printer , if you can take out the cartige holder out too , spray the cartige holder with a glass cleaning solution so it pours out from its bottom side , spray the ink cartige bottom , wipe it with a tissue then swing it hardly downwards so ink is poured from its bottom then wipe it with a tissue .
Oct 17, 2007 | Office Equipment & Supplies
168 people viewed this tip
jasbo
jasbo
