Tip & How-To about Computers & Internet
If RAM is not working or lose it will make a beep sound.
Computers & Internet Logo
I have dell vastro 1510 laptop & my problem is when i power on laptop there are continious beep sound & there is no display its blank.beep sound stops when i press any key on key pad but there is no display. i have tried by removing & reinserting the ram but the condition is same as earlier.please give some suggestion about the problem. thanks in advance.
Two long beeps is the universal code for memory issue. I would contact Dell and have them tell me what the number of beeps signifies (after you count them) and then you can attack the area. At least the bios is working when you get those codes - a relief because if you lose the cmos you are in deep doo doo. Could be a bad peripheral, connection, etc.
Sep 10, 2017 | Dell Vostro 1510 Motherboard System Board...
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
No VIDEO!!
Dear,
pl check step by step.
first to hang up all hardware ram,smps,processor with heatsink fan,keyboard all.
After check any beep sound comes from motherboard.
remove ram and check beep sound
remove cmos cell,ide cable and check beep
sound.
NO COMES ANY TYPES OF BEEP SOUND PROBLEM IN *********** BOARD ALOSO CHECK YOUR RAM AND SMPS AT ANOTHER COMPUTER WORKING OR NOT.
Regards,
Ravindra shah
Jun 02, 2009 | Gateway (4000782) Motherboard
hello every 1 d845hv
If it is only since removing the ram and re-inserting it that there is no display, try removing the ram again and re-inserting them 1 at a time then switching on to see if there is any display. Make sure the ram is firmly in place in its socket before switching on. Also you do not mention if there are any beeps coming from the internal speaker when switching on. These beeps sound different for different problems and the way it beeps can tell you where the problem lies.
Dec 03, 2008 | Intel Motherboard
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
125 people viewed this tip
David Payne
David Payne
