Tip & How-To about Dryers
Does your dryer heat up but not dry clothes?
If your dryer is heating up but not drying your clothes the first thing you should check is the lint trap and exhaust on the dryer itself for any obstruction. Second is the ducting and outside vent for the same. If you live in an area with dangerous spiders, insects, scorpions, and snakes this may be a good place for them to live. NEVER PUT YOUR HANDS ANYWHERE YOU CANNOT LOOK INTO FIRST! Be careful for sharp sheet-metal and screws. Obstructed air flow is the most common problem in this scenario.
Dryers Logo
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
why does the dryer take an hour and a half to dry a load of clothes
GE dryers usually have more than one heating element. Your machine probably has one failed heater and one good heater. The dryer will not get hot enough with only one heater working.
Unplug the machine! Check the heaters for continuity with a multimeter and replace if no continuity.
If the heaters are good, a faulty operating thermostat can also cause this symptom. It can turn the heaters off before the machine reaches the normal operating temperature.
Poor air flow can also contribute to slow drying. Check for lint buildup blocking airflow inside the machine and the vent duct.
Apr 28, 2010 | GE DBXR463EDWW Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
The dryer is overheating.
Fresh air is drawn in past the heating element into the drum out through the lint trap and exhausted outside the building. If the dryer protection systems are operating properly they will sense the over temperature and shut off power to the heating element via thermal switches. This will cause the elements to cycle on and off and reduce the drying ability.
Things to check.
First make sure you fill the dryer only about half full of clothes, usually the dryer capacity is around twice the washer capacity for this reason.
Second, make sure your lint trap and exhaust duct work from inside the dryer all the way outside are free from lint build-up. You should clean or have the dryer duct work cleaned either every year or two depending on the amount of drying you do.
Third, suspect is the dryer thermostat stuck in the on position. You may be able to test your drying temperatures by selecting (cold) fluff air setting, then the low setting and so on to see if that's working properly. If you can read electrical drawings, usually the manufacturer includes a diagram inside the control panel for service techs to refer to. You can test the flow of air out of the dryer by removing the hose from the exhaust, it should have a good volume of air when the dryer is running. After hooking the hose back to the exhaust duct work, check outside the building for the same air flow and don't forget to clean any outside flaps that keep the rodents out of the duct work.
Keep your lint low by not over drying your clothes. You will cut down on lint and prolong the life of your clothes! Dryers are one of the simplist appliances to figure out, unless they have complicated electronic control panels.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
217 people viewed this tip
Top Dryers Experts
Dan Webster
Dan Webster
