Tip & How-To about Dishwashers
What causes my timers to burn out on my washer, dryer and dishwashers
When setting your tmers on your washers, dryers and dishwasher, Do not turn the timer while the machine is in operation. When this happens the timer contacts are arcing and burning. on dishwashers and dryers, Open the door slightly to set the timer. never turn the timers while the machine is in operation. Timers are expensive to replace. If you need to replace a timer, you may consider the cost of a new machine with a warranty. Warranties do not cover timer abuse.
Dishwashers Logo
What is causing erratic operation?
This sounds like a bad timer. As you turn the timer knob, cams on the shaft causes contacts to open and close. It is not unusual for the contacts to fail to close / the cams may wear down and not activate the contacts. This happens on one or more settings while other settings continue to work.
Dec 11, 2015 | Admiral AED4475TQ
I have a kenmore front load washing machine that water shuts off after 5 seconds. Timer continues to count down but nothing happens in the machine. Timer also takes about 3x longer to get to zero.
Troubleshooting Appliances: Washing Machine and Dryer ...
www.realestate.com > Realestate.com Blog > Articles
Sep 16, 2012 - If your washing machine or dryer seems ready to give up the ghost, follow ... When you start your washer, a solenoid-operated water inlet mixing valve ... Afront-loading washer lacks the agitator, instead using the tumbling ... Clothes Remain Wet After the Spin Cycle. 1. .... Bought washer/dryer second hand.
Oct 19, 2015 | Kenmore Washing Machines
Malber WD1000 dryer timer starts running immediately when set, even in the middle of wash cycle
Call in the troops! You need to have the controller panel opened and checked for excessive lint and dirt. There is a short or two in that mess!
Dec 26, 2012 | Malber WD1000 Front Load Washer/Dryer
kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
MY LAT8824AAE machine just fills with water
if the tmer works on any of the cycles but not on all of them, you might need to purchase a new timer.
Mar 23, 2007 | Maytag LAT3600A Top Load Washer
235 people viewed this tip
Top Dishwashers Experts
