Tip & How-To about Computers & Internet
What is a Dell service tag?
When you buy a new computer from Dell, it comes with a service tag affixed to it. The service tag is a barcoded sticker put on the computer's case that makes your specific computer easily identifiable by Dell for repair, service, or support purposes. If you go to the Dell website (Support.Dell.com) and enter your service tag, you can view a list of drivers for your computer, so you can see at a glance if any of your current drivers are out of date and easily download any updates. You can also see your computer's specs and other details.
On a desktop computer, the Dell service tag is typically located on the back of the computer. On a laptop, it's probably on the bottom. It is a rectangular white sticker with a short barcode and a mix of five to seven letters and numbers underneath the barcode. Depending on your system and how it was set up, you may also be able to find your service tag number through your computer's setup utility. (If you have an OptiPlex GX280, for example, the service tag can often be viewed in the CMOS settings.)
In addition to computers, Dell also affixes service tags to their other products, including routers, TVs, and printers. Knowing your service tag number can make using Dell's online or phone support much easier. It's a good idea to write the service tag number down somewhere or store it in a file, in case the sticker peels off one day.
Computers & Internet Logo
How to fix Dell Latitude E5430 ERROR??
dell has a great thing , its called a service tag , all one needs to do is find service tag (sticker on case someplace) and go to dells web site with that number find service tags fixes and down load a new copy of the drivers to install
Oct 20, 2015 | Dell Latitude E5430
How do I unlock a keyboard on my Dell inspiron 5737-
You locked the access within the OS. You did state that it is a new computer in which case you can contact Dell technical support and work with them. A number for them is 866-516-3115
Make sure to have your Service Tag handy when you call them. You will find the service tag on the bottom of the Notebook on a (most likely) a black sticker with white writing that says Dell and it will list your service tag and your express service code. Some one is at that phone # 24x7x365
Jun 09, 2014 | Dell InspironTM 1501 Notebook
where is optiplex 755 mini tower service tag #
This is generally in a few places. It should be on a sticker on the front or top of the tower. There will also be a sticker on the back side of the chasis. It's an alphanumeric string 7 characters long. The sticker on the back may have a bar code above and below it on the sticker. You can also get the service tag from BIOS in most cases.
Feb 04, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
what components need to be installed in the dell inspiron 1501?
on the laptop will be a service tag sticker (normally white with a barcode), go to dell.co.uk and type in the service tag code (appox 7 characters) and it will bring up all items needed to be downloaded for this pc.
as dells are made to order so to speak this is the best option for ensuring the right downloads are made for your pc
Mar 19, 2010 | Dell Inspiron 1501 Notebook
need to fine key code or service code
dell service tag or express service code u mean ? on back side of pc there is a white sticker with a barcode and a number. there.
Oct 07, 2008 | Dell Dimension 2400 PC Desktop
254 people viewed this tip
David Payne
David Payne
