Tip & How-To about Computers & Internet
How to resolve a "NO VIDEO" problem on your Desktop computer?
1. Turn the computer off...
2. Remove the Power cable and drain the power by holding down the power button for 10 seconds...
3. Remove the side panel of your CPU Tower (refer to manual how to remove side panel)...
4. Loosen the screw of your Graphics card and remove it then replace it back!
5. Connect all cables and put the cover back...
6. Turn your computer back on!
Note: This trick applies to desktop pc's with video card. If your graphics is integrated with your motherboard, try reseating the video cable instead.
Computers & Internet Logo
my hp 6300 front panel lights are not working...how do i fix
Try below resets, one after the other if issue persits.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
May 30, 2011 | HP Officejet 6310 All-In-One InkJet...
MY HP OFFICEJET 6 310 ALL IN ONE INKJET PRINTER IS FLASHING RESET POWER
Please follow below resets.
Power Drain:
Partial Reset
Semi-Full reset
NVM Reset
Regards,
Riztech
Oct 24, 2010 | HP Officejet 6310 All-In-One InkJet...
the off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
Partial Reset
Semi-Full reset
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
I just purchased this "great" printer and as it was doing its intial setup it gave me the paper jam error! There is no visible paper jammed - what is another solution
Hi John,
Try the below solution to fix this problem.
Step 1: Power Drain
Step 2: Partial Reset
Step 3: Semi-Full reset
Regards,
Rizwan
Jan 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
216 people viewed this tip
David Payne
David Payne
