Tip & How-To about Computers & Internet
How to uninstall a program completely from pc
Many times there are times when you uninstall a program but then you go into your folders and you see there is empty folders or still files left over, well i got a solution to that problem, Installing a 3rd party program like advanced uninstaller will leave your computer looking like you never installed that program, because it deletes all its traces and empty folders,, if you want to save alot of space on your hard drive i recommend downloading advanced uninstall or revo uninstaller...
Computers & Internet Logo
it gives error that your hard drive have 1mb free space
1. Go in control panel Add or remove programs or programs and features then uninstall the programs that you don't use or havn't used in a long time.
2. Go in control panel Folder options view tab at the top. Look for Hidden files and folders put a tic in show hidden files and folders.
Go in My Computer/Computer Click on the c drive then windows folder delete the update folders that have a $ infront of the name of the folders. Go back to Folder Options/View tab at the top. Hidden files and folders put a tic in Do not show hidden files and folders.
3. Right click on Rec bin choose empty rec bin.
4. Go in control panel / Internet Options clcik on settings next to the first delete button from the top then click on view files. On the upper roght clcik on edit/Organize choose select all. Then hit your delete key on your folder yes to conferm. Click on ok then in the next window click on delete button next the settings button you clicked on before.
5. Open notepad type del %temp% /q then save the file to your desktop name it Del.bat cloce everything out and double click the del file on your desktop.
6. Open the run command Hold the windows key down (left of the space bar on your keyboard) Press the r key. Type in %temp% Delete all the files and folders you can in that folder.
7. Right click on Rec bin choose empty rec bin.
If it still says low disk space I suggest saving your personal files and reinstall your oem system disk or add a second disk drive.
Terry
Apr 03, 2014 | Computers & Internet
I have CreataCard Platinum 8 version installed on my computer. Recently, I had to uninstall it and then re-install it due to some computer problems. I just tried to access the program and I keep getting a pop-up message that says "Cannot determine configuration." I tried to uninstall the program so I could reinstall it from the discs again, but my computer won't let me uninstall it now! Can you please help me???
Hi.
If you are unable to uninstall the software by way of 'Add or Remove Programs' or 'Programs and Features', it will be necessary for you to perform a manual uninstall by searching the hard drive for files and folders related to the program you want to uninstall. then manually removing those files and folders.
Many programs will install files and folders in several locations on the hard drive. And, even when it is possible to uninstall software by way of 'Add or Remove Programs' or 'Programs and Features', it is always a good idea to conduct a search of the entire hard drive then manually delete any files, folders, icons and shortcuts that are found by that search because many uninstall processes do not remove all files, folders, desktop icons and Start menu shortcuts associated with the software.
After making sure that all files, folders, icons and shortcuts have been removed from the computer, empty the Recycle Bin, restart the computer, then run a registry cleaner until no invalid registry entries are found. It is advisable to run the registry cleaner REPEATEDLY (always restart the computer before running the registry cleaner again) because fixing some invalid registry entries can cause other registry entries to become invalid.
If you are uninstalling the program because you believe that the installation is corrupt, these steps are especially important . Making sure that all files, folders, icons and shortcuts are manually deleted and using a registry cleaner to remove all invalid registry entries is the best way to ensure that all corruptioIf you don't have a registry cleaner installed on your computer, you can download the free CCleaner by clicking on the link below
Download Latest Version of CCleaner
If you use CCleaner, you must remember to click on the 'Registry' button on the left side of the window before starting the scan. And, with CCleaner, running the registry cleaner repeatedly will often cause the same invalid registry entries to be displayed over and over. If that happens more than twice, the only option is to allow those invalid registry entries to remain - because indications are that those invalid registry entries are not truly
invalid at all.
There is also an option to try and uninstall a program using CCleaner. If you click on "Tools" option on the left hand side, click on "Uninstall" and look down that list for Creatacard and try and uninstall the software using that option.
The 'Cleaner' option in CCleaner is a very useful tool for cleaning out unnecessary files and folders on the hard drive. So, it is also be a good idea to run the 'Cleaner' option in addition to the 'Registry' option.
Once you are sure that all traces have been removed restart your computer and proceed to re-install the software again.
Hope this helps.
Regards.
Jun 02, 2011 | Broderbund American Greetings Creatacard...
I can't delete ArcSoft software from my add/remove area
I'll tell you, but you're going to have to go the long way. Best method I'm aware of.
Plus I suggest you download CCleaner. CCleaner is a free registry cleaner. (Don't let the fact that it is free, dissuade you one bit! It's a better registry cleaner program than the PAID for one's are! )
After you delete a program there are 'tidbits' left behind. Fragmented files. These take up space also, and in essence are just junk. Like having partial pages torn out of a book. A registry cleaner rids you of them.
This is information about CCleaner from Wikipedia.org,
http://en.wikipedia.org/wiki/CCleaner
After you view the information, and wish to download CCleaner, simply go to the right of the page, under the illustration, and click on the website address.
After you download CCleaner, come back if you wish, and I'll explain the easy way of how to run the program.
Long way of deleting a program, but assurance that it will be gone. (After using CCleaner also)
Windows XP Home running, Left-click on Start.
Hover your mouse cursor on All Programs, go up to Accessories, over and down to Windows Explorer, and click on it. (This isn't Internet Explorer, in case you are not familiar with Windows Explorer)
After Windows Explorer has loaded, go up to the top header. Left-click on Tools. Now on Folder Options in the drop down list. Finally Left-click on the View tab.
In the list, go down to where there is a yellow folder with - Hidden files and folders - to the right of it.
Below this you will see an empty circle, and to the right of it - Show hidden files and folders
Left-click once in this box.
Now go below to the right, and Left-click on Apply. Finally go down to the left, and click on OK.
After you do this a Microsoft 'squawk box' will come up. "Warning you are.........."
It's okay. Click on OK if present.
The reason this warning box comes up is that a user can delete necessary Windows files, IF, they do not know what they are doing.
I'm not going to guide you towards destructing your Windows operating system, rest assured. We are not going anywhere near Windows files. Just the ArcSoft program file that's about to hit the trashcan.
When you open Windows Explorer, the default setting is to automatically open your My Documents folder. You can see a negative sign ( - ) next to My Documents in the 'file tree' to the left, and the contents of your My Documents folder to the right.
I like to close the file tree for My Documents. Less clutter, and less chance of getting confused.
If you are of the same mind, go up to the - sign next to My Documents, and Left-click right on the - sign. It will turn into a + sign, and close that part of the file tree.
Now Left-click on the + sign next to,
1.My Computer
2.Then - Local Disk (C:)
3.Now scroll down to - Program Files
Scroll through these programs. See ArcSoft? Left-click on the ArcSoft name. The individual folders and files will appear on the right, in the large window.
Now double-click on a Folder. The folder will open, and display individual files. Right-click on a File, then in the drop down menu, Left-click on Delete.
You may not be able to delete the entire folder for ArcSoft, (Too large for Recycle Bin), but you can delete individual files, until the folders are empty 'husks'.
Then you can use the Back arrow at the upper left, and Right-click on the folder/s. Delete them.
You may come to a file that has an extension - .dll
You may not be able to delete this type of file. It's okay. After you shut down your computer, wait 1 minute, come back into Windows Explorer, and try it again.
Finally use CCleaner, and get rid of the file fragments.
I know this is long, and I apologize in advance. has worked for me to delete stubborn programs for years. (Norton, AOL, and others)
Has worked better than using the Uninstall feature, if the program comes with one, and any Uninstall option listed on the Internet for a program.
Have questions? I'm all ears.
Nov 08, 2009 | HP Mini 1000 Notebook
I have a classic iPod 80Gb. I have just loaded iTunes v8.1 onto my laptop using Vista home. When I try to ope iTunes the following message comes up:"The folder iTunes cannot be found or created and is required. The default location is inside the "Music" folder". If i look in the folder, there is a file folder called iTunes - it is empty. How can I get this to work? Regards
Uninstall the egzisting itunes by following steps. Start menu> Control panel>click on the Control Panel home on the upper left side>same windows you will see the programs and under Unisnstal a program waith for list of programs refreshes highlight Itunes and press the Uninstall tab and reinstall the Itunes
May 01, 2009 | Apple iPod MA446LL/A MP3 Player
145 people viewed this tip
David Payne
David Payne
