Tip & How-To about Computers & Internet
How to cross check your ISP charges your Internet usage fairly
I personally use NetWorx. Witch is a free and simple, yet powerful tool that helps you objectively evaluate your bandwidth situation. You can use it to collect bandwidth usage data and measure the speed of your Internet or any other network connection. NetWorx can help you identify possible sources of network problems, ensure that you do not exceed the bandwidth limits specified by your ISP, or track down suspicious network activity characteristic of Trojan horses and hacker attacks.
The program allows you to monitor all your network connections or a specific network connection (such as Ethernet or PPP) only. The software also features a system of highly customizable visual and sound alerts. You can set it up to alert you when the network connection is down or when some suspicious activity, such as unusually heavy data flow, occurs. It can also automatically disconnect all dial-up connections and shut down the system.
The incoming and outgoing traffic is represented on a line chart and logged to a file, so that you can always view statistics about your daily, weekly and monthly bandwidth usage and dial-up duration. The reports can be exported to a variety of formats, such as HTML, MS Word and Excel, for further analysis.
With NetWorx you can
• Find out and monitor how fast your Internet connection is.
• Find out and monitor how much Internet traffic you consume.
• Verify whether your ISP charges your Internet usage fairly.
• Detect a suspicious network activity on your computer.
• Perform simple network tests such as ping and trace route.
• Be notified about excessive Internet usage
You can download it from here.
Please Vote for this Tip if you found it helpful J
Computers & Internet Logo
They are asking me for the code
draw a flow chart of the situation. fit the loops and situation- switches to it and then start coding .... SIMPLE
Mar 15, 2016 | Computers & Internet
How to convert word to PDF?
Kernel for Word to PDF software is one such best and advance Word to PDF converter tool that allows you to easily convert word files with OLE objects, images, forms, graphs, hyperlinks, tables and other information to PDF in few seconds. The software supports MS Word versions: 2010, 2007, 2003, 2002, 2000, 98, 97, 95, and 6.0. Try free evaluation version: http://www.convertdoctopdf.org/
Jan 29, 2014 | Computers & Internet
using micromax data card 310g with bsnl 3g sim. i want to know how to get balance of remaining balance of the data or money through computer,
Dial *123*10#
or
but whenever you disconnect the usb data card,it shows the total usage and balance usage
or
Use a bandwidth meter like Shaplus or Networx. Will give you a rough idea.
or
If you don't have the option in data card... plug the SIM into your phone and dial *123*6# for data balance.
May 05, 2011 | Computers & Internet
calculation of router bandwidth
easiest way to do this is use QoS (quality of service) if your router supports it.
Jan 02, 2008 | Computers & Internet
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
187 people viewed this tip
David Payne
David Payne
