Tip & How-To about Computers & Internet
How to Reset ACER Aspire 5710G BIOS Battery
First I made a set of (2DVD)System DVDs to recovery this machine making the reinstall process easier after the battery reset is completed.
Tools you will need are ....
small philips screwdriver
soldering iron
Remove all power,both battery and ac power pack,
Turn laptop over on to its lid,
Remove cover from bottom of laptop exposing the motherboard,
There are 4 small screws holding this cover on here,
the battery is soldered onto the pcb in the corner,
it has a small blue plasitic ring surrounding it,
Turn the lap top around so the battery is next to your stomach,
With my hot soldering Iron, I heat the join on the right hand side of the battery until it melts then I gently pull away the battery leg from the pcb.
At this stage you must pay special attention to the leg of copper track attached to the other end of the battery,
this does not penetrate through the pcb as its a surface track,
too much heat will lift this track and make the track unreusable or broken ,
leave the battery to sit for approx 1 hour before soldering back on to the board and fit the power and restart the laptop.
Ok upon restart the start up screen has flashed up ok,
noticed the BIOS screen has also recognised the recent BIOS change too
Now we are ready for a system reinstall ,
Change your boot options to start from CD rom & we are back in business
Set BIOS to boot up from the CD/DVD first.
Insert System DVDs made earlier,
Shutdown and restart and the system dvd will now install a new OS.
The system will prompt you for the next disk when it ready,
This reinstall should take approx 45min,
I hope this helps everyone ,
Please Rate Me Thanks ,Cheers Misterdj
Computers & Internet Logo
i need to restart my computer to a factory settings
1st of all you need to take back up of all your important files and data.
Then Turn off your computer.
Remove everything but the monitor, keyboard and mouse.
Turn on the computer and when see the first screen, press F8 to open the Boot Options Menu.
In the menu you need to find System Recovery Options
Due to every PC different configuration, you need to select Factory Tools and then restore factory setting.
Presses the Yes button and restore system software to factory condition check box and click Next.
After the restore operation is complete, click Finish to restart the computer.
Hope this will work for you ! :)
Mar 24, 2017 | Computers & Internet
How do I get windows to reinstall on my irulu walknbook if the battery died during the first install? All I see is walknbook screen and pop up saying what you see in photo
Tutorial written on November 19, 2015 This tutorial will explain in detail how to reset Windows Tablet IRULU Walknbook. IRULU Walknbook If you want to return to the IRULU Walknbook to its factory settings, you only need to follow a set of instructions that give you here. We will explain two methods to achieve make the Windows reset. As a first step and before the hard reset, you must have charged the battery in your tablet as a whole, this for a blackout occurs during the process that damages the Windows operating system that has Reset Windows Tablet IRULU Walknbook by menu When you access the menu of your Tablet IRULU Walknbook follow these steps to reset a Windows fast and efficient. Swipe the menu and touch Settings Now it Change PC settings Select Update and recovery, then Recovery Touch Remove everything and reinstall Windows, select Next Choose the option to delete the unit completely Tap Reset You will see your Tablet IRULU Walknbook restart and start the process (this may take several minutes) When finished you will have been completed to make reset Windows Tablet IRULU Walknbook Reset Windows Tablet IRULU Walknbook using your keyboard This Windows reset is also very effective, just about to connect your keyboard to your IRULU Walknbook to carry out the process. Tap the On / Off icon on the login screen. Press and hold the Shift key while pressing touch Restart A menu will appear on the screen, select: Troubleshooting Tap Reset your PC Your Tablet IRULU Walknbook reboot and see the logo screen, wait a moment On the Reset your PC screen, tap Next Select the option: Delete the unit completely Touch Reset and wait a few minutes That's all, if you've done it correctly, you've managed to reset Windows Tablet IRULU Walknbook.
http://resetwindows.net/tag/irulu-walknbook/
Translated by google translate
Feb 17, 2016 | Computers & Internet
trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
Oct 05, 2013 | HP Compaq Presario SR1115CL PC Desktop
factory reset from CD
Click the "Start" menu on your computer and choose "Accessories." Click "System Tools" and choose "Back up" from the list. This process will back up any files on your computer that you wish. When you reset your HP to its default settings, all documents, programs and other files on your computer will be lost. Back up anything you may need later. Follow the on-screen instructions to move through the back-up wizard. When given the option "Let me choose what to back up," select all programs or documents you want to save. If you're unsure whether you'll need it, back it up just in case. Insert a blank CD or DVD to save your files. Choose your CD drive from the "Back up location" option in the backup wizard. Keep multiple blank CDs or DVDs on hand. You'll need a lot of space, and typically several CD's, to back up all your information. Click "Finish" at the end of the back-up wizard and it will begin to burn information to the CD or DVD. When prompted, remove the CD and insert a new one. Continue until the computer is done backing up your information. Label each CD or DVD in the order you burn it. This way you can transfer your information back into the computer in the order you saved it. Check your CDs or DVDs to make sure the back up was complete by opening a file from the CD. Exit any open programs. You are now ready to start the restoration process. Click the "Start" menu, "All Programs," "System Recovery," and choose "PC Recovery." Choose "PC Recovery" again once the menu opens and click "Next." Your computer will restart automatically. When it turns back on, a welcome message for the PC Recovery software will display on screen. Click "OK." Select the "System Recovery" option to restore the computer to its default settings. Follow any on-screen instructions and wait for the computer to finish resetting your settings to the default. Insert your first back-up CD or DVD to start reinstalling your programs after boot-up. Open the files and save them to the computer. After you've saved everything from the first CD, continue on with the rest. Hope this helps.
Jan 09, 2013 | HP Computers & Internet
I have a spywhere infection on my advent laptop how do i resore to factory settings?
Using the HDD Recovery System
Your Advent computer uses the latest recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
There are two ways to start the recovery -
Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
The recovery will load and display a box with one option:
Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Select the Non-destructive recovery option and press Next.
You will be informed about System Restore in Windows, click Yes.
The recovery will begin. Once this is complete click Restart.
Feb 28, 2011 | Computers & Internet
1,343 people viewed this tip
David Payne
David Payne
