Tip & How-To about Computers & Internet
Intel or AMD for a laptop?
When it comes to buying a new laptop one of the main things you should look for is a good processor.
Intel is a bit more expensive than AMD is but is more reliable.
Intel also has an auto shutdown feature in their processors when the chip overheats. This is a key feature when it comes to laptops because the main issue with laptops is overheating. Overheating is the main cause to parts going bad in laptops as well.
AMD is a good amount cheaper than Intel. AMD still makes very good processors but most of them lack the auto shutdown feature that Intel provides. This can be an issue when it comes to overheating.
AMD: Only go with AMD if you believe you can maintain a cool pc. If you have any doubt that you can do so then go with Intel.
Intel: If you can afford to make the investment in a cooler more reliable pc with an Intel chip then go for it. It's the better decision. But if you don't choose Intel then i recommend buying a chill mat with the computer to increase the life expectancy.
Computers & Internet Logo
contact form
i want the password to be dominic20
Sep 18, 2013 | Acer Extensa Computers & Internet
I am seeing in most of the new computers, the AMD processor. Because I am shopping for a new computer I asked an employee at Best Buyif AMD is better than Intel, he said that AMD is four levels below Intel, implying that Intel has the better processor. But, why do 95% of the new pc's have AMD? Which would you reccommed?
For all out performance and raw speed, intel procesors are the way to go. Intel processors are fast, high quality and they have been around for a long time. On the other hand, AMD processors have descent processors for a good budget price, which may explain more pc's using AMD. Also, I have heard that AMD uses different materials than intel which make the less likely to overheat. For general, everyday computing an AMD processor should be fine.
Sep 09, 2011 | Computers & Internet
AMD vs Intel
your selected processor is so better than intel.amd provides better graphical support than intel.
Jan 14, 2009 | Computers & Internet
buying a notebook
Please go for this my friend has bought its rockz man
Compaq Presario V6700TX series Operating system
s.gif Operating System
  • Genuine Windows Vista Home Premium (32-bit)
Processor
  • From: Intel Core 2 Duo Processor T5450 (1.67 GHz, 2MB L2 Cache, 667MHz FSB)
  • Up to: Intel Core 2 Duo Processor T7250 (2.00 GHz, 2 MB L2 Cache, 800MHz FSB)
s.gif Processor
  • Pentium Dual-Core Mobile Processor T2330 (1.6 GHz, 1MB L2 Cache, 533MHz FSB)
Display
15.4" WXGA high-definition widescreen with BrightView s.gif Display
15.4" WXGA high-definition widescreen display with BrightView Dimensions
14.05 (L) x 10.12 (W) x 1 (min H)/1.69 (max H) s.gif Dimensions
14.1 (L) x 10.11 (W) x 1.29 (min H)/1.58" (max H) Weight
5.99lbs
Weight varies by configuration s.gif Weight
6.4 lb.
Weight varies by configuration Communications
Available Intel PRO/Wireless 3945ABG network with optional Bluetooth s.gif Communications
802.11b/g wireless LAN Broadband wireless
N/A s.gif Broadband wireless
N/A Graphics
Intel Graphics Media Accelerator X3100 s.gif Graphics
Intel Graphics Media Accelerator X3100 PCI expansion
Expansion port 3 connector s.gif PCI expansion
N/A Memory
From 1.0GB to 2.0GB DDR2 SDRAM s.gif Memory
From 512MB to 2.0GB DDR2 SDRAM Hard disk drive(s)
Up to 160GB 5400 rpm Serial ATA hard drive
Price $789.99*
regards-balisonu79
Feb 15, 2008 | Computers & Internet
I want to upgrade my Compaq Presario 1200 AMD laptop Hard Drive - any limitations?
Several companies such as AMD and Cyrix are also developing processors which are completely compatible with Intel processors. This means that they are capable of emulating every processor instruction in the the Intel chips.
INTEL SOCKET INFORMATION
Intel designed a set of sockets. Each of these sockets supported a certain range of processors. Below we have listed the complete specifications and layouts of each of these sockets.
socket1.gif SOCKET 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
SUPPORTED PROCESSORS
169 Pins 17 x 17 PGA 5v SX / SX2, DX/DX2, DX4 OverDrive
socket2.gif SOCKET 2 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
238 19 x 19 PGA 5v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket3.gif SOCKET 3 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
237 19 x 19 PGA 5v/3.3v SX/SX2, DX/DX2, DX4 OverDrive, 486 Pentium OverDrive socket4.gif SOCKET 4 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
273 21 x 21 PGA 5v Pentium 60/66MHz, Pentium 60/66 OverDrive socket5.gif SOCKET 5 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
320 37 x 37 PGA 3.3v Pentium 75-133, Pentium 75+ OverDrive socket6.gif SOCKET 6 SPECIFICATIONS Slot 6 was thought and planed of, however was never actually ever implemented in any system.
PINS
PIN LAYOUT
VOLTAGE
235 19 x 19 PGA 3.3v DX4, 486 Pentium OverDrive socket7.gif SOCKET 7 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
321 37 x 37 PGA Voltage Regulator Module Pentium 75-300, Pentium 75+ OverDrive slot1.gif SLOT 1 SPECIFICATIONS
PINS
PIN LAYOUT
VOLTAGE
242 Slot Voltage Regulator Module Pentium II / Pentium III Processors
PROCESSOR HISTORY AND INFORMATION
Below is a listing of all known processor manufacturers made to date. In the below list is information about major processors listed by the date manufactured as well as a brief description of the technology and advances of each of the processors.
INTEL 4004 - Microprocessor introduced in 1970 with the speed of 108KHz was the worlds first microprocessor.
INTEL 8080 - Microprocessor introduced in 1974 running at the speed of 2 MHz was used in the world's first PC, the Altair.
INTEL 8086 (Code Name: P1)- Microprocessor first introduced in 1976. The 80086 had a 16-bit architecture that allowed it to work with 16-bit binary numbers and pass them through a 16-bit data bus. The 8086 was available in clock speeds of 5MHz, 8MHz, and 10MHz.
MOTOROLA 68000 - Microprocessor released in 1979 was later chosen by Apple for the Macintosh computer.
INTEL 8087 - Floating-point math compressor compliant with the 8086 / 8080 microprocessor family.
INTEL 8088 - Microprocessor released in 1979. The 8088 was the first Processor used in the original IBM PC and XT personal computers because it was less expensive than the 8086 microprocessor because of the availability of less expensive eight-bit data bus supporting chips made it the microprocessor for the IBM PC. The 8088 was available in speeds from 4.77 MHz and 8MHz.and used the 16-bit architecture allowing it to work internally with 16-digit numbers. The 8088 had the ability of addressing up to 1MB of RAM.
INTEL 80286 (Code Name: P2) - Microprocessor introduced by Intel in 1982 which commonly is referred to as the 286 processor. The 286 processor supported 16-bit architecture, supported virtual memory, and was available in clock speeds of 8MHz, 10MHz, and 12MHz. The 286 was around 20 times faster than the predecessor 8088.
INTEL 80287 - A compliant processor to the 286, a floating-point math coprocessor. Specially designed 286 chips have the capability of placing the optional 80287 processor on top of it, giving the computer a math coprocessor.
INTEL 80386DX (Code Name: P3) - Microprocessor manufactured in 1985 was the next generation of Intel processors. The 80386DX included the math compressor, unlike the 80386SX, and still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
SPARC - Released in 1987 is short for Scaleable Processor ARChiture by Sun - used RISC (Reduced Instruction Set) to speed up processing.
INTEL 80486DX (Code Name: P4) - Microprocessor released April 10th 1989. The 486DX featured a built-in memory cache and 32-bit architecture. It had more than three times the computing power of the 386DX and was available in clock speeds of 25MHz, 33MHz, and 50MHz.
INTEL 80386SX - Microprocessor introduced in 1989 was the next generation of Intel processors. The 80386SX lacked a math coprocessor but still featured the 32-bit architecture and built-in multitasking. The chip was available in clock speeds of 16MHz, 20MHz, 25MHz, and 33MHz.
Good Luck, Please dont forget to Rate/Thank You.
Jan 17, 2008 | Compaq Presario 1200 Notebook
167 people viewed this tip
David Payne
David Payne
