Tip & How-To about Hand Tools
Today's vehicles come equipped with halogen head lamp bulbs, they are brighter and for the most part a lot easier to replace then the old style bulbs of years past. When replacing any halogen type bulb please be careful not to allow your fingers to touch the glass on the bulb, your skins oils can shorten the bulb life by half being they develop high intense heat, which explains why they are so bright and excellent for night driving. Also please use care when installing a light film of dielectric grease on the electrical connector plugs, don't get that grease on the bulb either, the dielectric grease keeps the connectors moisture and corrosion free for extended bulb life as well.
Hand Tools Logo
How do you replace a low-beam headlight on the 2005 Buick Rainier? I do not even understand how to remove the front grille?
Most vehicles are equipped with Halogen bulbs that are small bulbs that are replaced from under the hood behind the headlight bezel assembly.
They have a twist turn method generally to remove/replace hiowever they cannot have your hand come in contact with the glass bulb as the oils on your skin will in fact reduce the halogen bulbs life as it gets extremely hot burning the oil off the lense shortening the bulbs existence.
Remember to replace the bulb with the proper bulb as you may find two or three different applications of halogen bulbs for the same vehicle, they all have a purpose, they go from bright to brighter to brighter each increase in candle power also increases in price of the bulb, a typical standard priced Halogen is approximately $9.95 and up.
May 08, 2010 | 2004 Buick Rainier
WHAT IS THE BULB NUMBER FOR THE BRAKE LIGHT ON 2005 TRAILBLAZER
2005 CHEVROLET Trailblazer
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3757ALL
Front turn signal
3757ALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
Assembly
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3157LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
194
Dome light
212-2
Step/Courtesy light
194
Trunk/Cargo area
212-2
Nov 19, 2009 | 2005 Chevrolet TrailBlazer
need to know what size bulb goes in dome light
For 1991 TOYOTA Pickup replacement bulbs, review the list and check it in other brand with this model:
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
Front turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
License plate
194
89
Back up light
1156
Front sidemarker
194
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Hope helped with this (remember rated this help). Good luck.
Nov 11, 2009 | 1991 Toyota Pickup
212 people viewed this tip
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
