Tip & How-To about Computers & Internet
Increase WinXP explorer browsing speed
Open the Folder Options Control Panel, select the View tab, uncheck "Automatically search for network folders and printers"
Computers & Internet Logo
how I w8 show hidden files?
Open the side bar and select the Search option.
Type Folder and you should see 'Folder options', click it to open the window.
Select the View tab.
You can then changed the folder view options as needed from here.
Aug 22, 2014 | Computers & Internet
HP1020 problem with a livebox and WIN7 configuration
I found it somewhat difficult to completely Unshare files and folders on my HomeGroup Network and still allow Printer sharing in Windows 7 (Home Premium).
Initial UnSharing still allowed files like those below to be viewed on other home network computers:
C:/Users/
{user x} (folder)
AppData (folder)
Default (folder
Public (folder)
desktop.ini (file)
Other computers on the home network could step through many levels of hiarchy in the AppData folder and appeared to have "Delete" access!!
To completely decouple the computers, I had to go through the following several different Sharing/Unsharing assignment locations, till I could completely break the linkage.
I would appreciate any clarifications or simplifications.
File UnShare Confusion on HomeGroup Network
There are several different Network Sharing/Protection assignment locations in Windows 7.
To prevent all sharing between computers on the Homegroup Network, but allow Printer Sharing:
1) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options.
Uncheck sharing boxes that you don't want to share. Save changes.
2) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Click "Turn off Public folder sharing (people logged on to this computer can still access these folders)".
3) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Choose Media streaming options.
Click "Block All" button. Turn off. Click OK.
Anomaly Note: You have to close Control Panel and repeat all step 3 again for the change to take effect.
4) Open Windows Explorer.
a) Select "C:/", select "Users" folder with single click, then click "Share with" in toolbar.
b) Select Advanced sharing.
Under Sharing tab, select Advanced Sharing. Uncheck box labeled "Share this folder". Apply and close.
5) Open Windows Explorer.
Select "C:/Users/", select all folders and files under "Users", then click "Share with" in toolbar, then click "Nobody".
6) Verify success by going to other home network computer(s) and trying to access your files and folders. You should only be able to see there is a computer and not be able to see any folders of files.
smooth printer service
Dec 16, 2012 | HP LaserJet 1020 Printer
documents and settings is hidden
First, open Folder Options either through the Control Panel, or click the Tools/View menu on Windows Explorer and click Options or Folder Options. Click the VIEW tab then locate and select the SHOW HIDDEN FILES AND FOLDERS option, then click APPLY/OK. Afterwards, you should be able to see the DOCUMENTS AND SETTINGS folder. You may then right-click on it and choose Properties then uncheck/deselect the HIDDEN option and click APPLY/OK. If you prefer, you can then go back to the Folder Options to hide HIDDEN FILES/FOLDERS from Windows Explorer again.
Dec 06, 2011 | Dell Computers & Internet
how to find a hidden doument that is taking up loads of memorey on a almio pro
If you are using Windows XP, to show hidden files:
1.
Open Folder Options in Control Panel.
Click Start, and then click Control Panel.
Click Appearance and Themes, and then click Folder Options.
2.
On the View tab, under Hidden files and folders, click Show hidden files and folders.
For Windows Vista and 7:
1. Open Folder Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clickingAppearance and Personalization, and then clicking Folder Options.
2. Click the View tab.
3. Under Advanced settings, click Show hidden files and folders, and then click OK.
May 08, 2011 | Computers & Internet
when i double click the my computer icon, it takes forever to open up
What is the RAM of your desktop? First check the RAM, adding RAM is always the first and most effective way to improve computer speed.
Then, how many programs start when you boot up your computer? The more programs automatically start, the slower you computer boot. Click Start>Run>type in "msconfig">select "Boot", then you can see a list of auto-start programs. Disable unnecessary ones.
Computer slowdown is always related to redundant registry data and errors. Get a good registry optimizer, clean the errors, then defrag registry to speed up application response.
Jan 07, 2010 | Computers & Internet
140 people viewed this tip
David Payne
David Payne
