Tip & How-To about Computers & Internet
How to use antivirus safely to protect your system?
You should first store your Anti Virus(AV) program in a CD/DVD (pen drive not recommended) and while storing it you must use a 100% virus free PC or you use the CD you got while you purchased AV. You should install AV while your system is virus free and at that time no worm will damage your AV program (as at the installation time your AV does not work so existing virus in your system can attack your AV and it will not work later). Always activate your AV through internet. You must update the program or it will not work properly (after updation you will find your AV will catch more viruses from your system)
Computers & Internet Logo
what is the cheapestprogram to purchaseto remove a virus
Unfortunately, once a computer is infected with a virus of some sort it may prevent the installation of any antivirus or antimalware software. I suggest you download and try to install the free version of Malwarebytes and perform an initial scan to see what it finds. I would then install the free version of Avira or AVG antivirus (one but not both) and run scans. If neither of these steps finds and eliminates the problem you can attempt to run System Restore (WindowsXP or higher only) and restore the system back to a time prior to when you noticed the virus. If you cannot remove the virus with any of these methods you will most likely need to backup your data, format your hard disk and reinstall the operating system.
Oct 09, 2014 | Computers & Internet
program/virus removal
Not quite sure what you mean by how do i remove do searches ?
There are two possiblities
Oneyour old anti-virus setting is not remove from your PC.
Install crap cleaner (ccleaner) to get rid of the anti-viruses left over setting in the windows registry.
http://www.softpedia.com/progDownload/CC...
Two - a virus is preventing you from installing anti-virus
Use another clean PC to download Clamwin portable anti-virus and install it on a USB pen drive.
http://portableapps.com/apps/utilities/c...
Document on how to configure ClamWin
http://support.real-time.com/open-source...
Start Clamwin anti-virus and update the latest anti-virus definition files.
Select the tools menu bar, set the preferences to remove virus.
Start the infected PC in safe mode by pressing F8 during start up.
Run the Clamwin Anti-virus on the USB pen drive to scan the infected PC.
or
If you have tried all the various AV Removal Tools to look for expired/leftover remnants of other AVs, I\'d suggest scanning your System for Malware.
Malware will often stop you downloading Security Products.
Download, install, update and scan with each of the two programs below to check for/remove Malware/spyware.
If necessary, do all the above work in Safe Mode with Networking.
To get into Safe Mode with Networking, tap F8 right at Power On / Startup, and use UP arrow key to get to Safe Mode with Networking from list of options, then hit ENTER.
Read all info below before starting:
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Jan 26, 2014 | Computers & Internet
I just got a Dell Inspiron 4150 laptop from a family member (his old one) and can't seem to get the cd/dvd drive to open. Also, noticed that the cd/dvd drive does not show up as a separate drive letter in "my computer". The battery will need to be replaced due to not holding a charge. I want to add a virus protection and can't get the CD into the drive to install it. Any suggestions?
You can try the steps below and this should fix the issue.
Edit the registry:-
1. Click Start, and click Run.
2. Type regedit in the Open box, and click OK.
3. In Registry Editor, click the plus (+) sign next to each folder name to expand the following registry path:
4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the right pane, right-click Upper Filters, and click Delete.
7. Click yes when prompted to delete the registry value.
8. In the right pane, right-click Lower Filters, and click Delete.
9. Click yes again.
10.Close the window and restart the computer
Please do not forget to rate the solution.
Regards,
Musheer
Jan 20, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
(Dell )DVD player wont show any video
Get rid of Norton..........
Go to www.trendmicro.com, and do the free scan Trend Micro's House Call virus, spyware and malware scanner and cleaner. http://housecall.trendmicro.com
If you have anything, remove them. Helpful Free Software below Read On.
FREE SPYWARE
Download Spybot Search & Destroy. Restart computer, then run Spybot to see what spyware comes up, AND DELET IT.
FYI---Virus Protection-- 2 programs of virus protection will conflict with each other and will actually cancel out the protection. SO just download one.
Running Spybot Search & Destroy with EITHER Avast or Avg (great Free virus protection programs ) will keep a computer in good working condition. FREE
Avira AntiVir – Free Anti-Virus Protection
http://www.free-av.com/
FROM MICROSOFT 2009 -Free --Security Essentials
http://www.microsoft.com
Pop up Blocker- free
www.panicware.com
Spybot - Search & Destroy 1.5.2 -FREE SPYWARE
http://www.download.com/Spybot-Search-De…
Avast- FREE ANTI VIRUS PROGRAM
http://www.avast.com/eng/home-registrati…
AVG- FREE SPYWARE PROGRAM
http://www.free.avg.com
Ccleaner- FREE
http://www.download.com/3120-20_4.html?q…
Malware- FREE
http://www.malwarebytes.org/.
$ *** KASPERSKY ***
http://www.kaspersky.com
There are alot of $ anti-virus and Internet security programs out there-ie: Norton, McAfee, Panda, Bitdefender. If you would like to pay $ then get ***Kaspersky***-- 2010 , I feel that is the best for your money.
REMEMBER TO KEEP UP THE DAILY MAINTENANCE ON ALL OF YOUR COMPUTERS.!
Dec 05, 2008 | Dell DVD-rom DVD Drive
113 people viewed this tip
David Payne
David Payne
