Tip & How-To about Cell Phones
NOKIA PHONE-LOCK RESET Q. What is a Phone Lock? Answer: From Nokia's webpage: "The Phone Lock prevents your phone data from being accessed if Your phone is stolen. "The lock code is a number that prevents unauthorized persons from Using your phone. These control codes are for your protection." What is THE-NOKIA-UNLOCK: The program exploits a design flaw in the nokia mobile phones to remove The Phone Lock protection. The program was tested on Nokia 6630 and Nokia 6680. The program Should work on any other Symbian based mobile phones (including Sony Ericson and all modern nokia phones and many others). This tool does not remove the sim-lock. How to use: You need two mobile phones. 1) Do _not_ turn off the mobile phone! 2) Remove the Memory Card (MMC) from the locked phone and put it into a second mobile. Install FExplorer on the second mobile phone. Create the directory E:SystemRecogs and copy the-nokia-unlock.mdl into this directory. 3) Remove the Memory Card and place it into the locked phone. The THE-NOKIA-UNLOCK program should start after 120 seconds. 4) Remove the battery. Remove the MMC. Put the battery back and restart. The Phone Lock has been reset to "12345". Why does this work? The Phone Lock disables the key pad, Bluetooth and the USB port. This makes it impossible to access the data stored on the device without knowing the correct code. Nevertheless the MMC is not disabled. Nokia's OS has a lot of undocumented features. One of them are 'recognizer' that can be used to execute a program when the phone boots. A recognizer is loaded and executed when a drive is mounted. The MMC is mounted when it is placed into the mobile phone _even_ when the phone is locked. THE-NOKIA-UNLOCK is a recognizer that implementes yet another undocumented feature to perform a hard reset (by software) on the phone. Note: The same recognizer-autostart method can be used to quickly install a backdoor on a locked mobile phone or to propagate a virus: Get in, Get Out, Get Away.
Cell Phones Logo
my nokia n8 working only offline mode .not orking in genral mode how to repar
maybe check ur sim slot or try ur sim to other phone if is no signal ur problems its in sim if not at same try to hard format ur n8
If you're unfortunate enough to encounter a problem on your Nokia N8, a hard reset maybe what you need to do. This wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it. It's also useful if you're also unfortunate enough to have to send away your Nokia N8 for repair or exchange, or maybe in future you maybe selling it and don't want your information/details/media stored onto your device for someone else to access.
Hopefully unlike the N97, the N8 will not encounter hard-reset bugs where we constantly have to hard reset.
To hard reset the Nokia N8:
1) Turn off your phone
2) Hold "Volume Down + Camera Key + Menu Key" and press power button until your phone vibrates.
or try this one
How to Master Reset Nokia N8 do the Factory Default Setting?
If our Nokia N8 have problem such as hang or not responding or slow or stuck or have problem or frozen, then what we can do is try to restart the phone first to erase all temporary file and clean the cache. If the Nokia N8 problem still there then the last thing we can try is to do Master Reset to Factory Default Nokia N8 with safety way.
#Option 1, Hard Reset Nokia N8 with Menu Setting:
If we still can access the menu, then do this step:
  1. Go to Setting Menu
  2. Choose Phone
  3. Choose Phone Management
  4. Choose Factory Setting, after that choose Delete Data and Restore
  5. The Nokia N8 will reset all data for factory default, please remember before doing this step for always backup any important data before it deleted.
#Option 2, Hard Reset Nokia N8 with Hardware Key Button:
If we can not access the menu with screen, or the LCD is not responding, we have to hard reset Nokia N8 with secret button key:
  1. Make sure you understand that all data will be deleted, so do backup as you can
  2. Turn off the Nokia N8
  3. Press the Hardware key together: Volume Down Button + Camera Button + Menu Button
  4. Still continue the no.3 step (do not release), continue with pressing Power Buttonwait until the phone vibrate to start the factory reset Nokia N8 automatically.
#Option 3, Hard Reset Nokia N8 with Secret Code and Phone Lock Code:
If we want to format Nokia N8 with security code, try this :
  1. Make sure you already backup all important data before do the factory reset
  2. From the Phone Positions, type : *#7370#, after that press YES
  3. It will ask the Phone Lock Code, if you never change it, the default Phone Code of Nokia N8 is 12345
  4. What about if we forget the Phone Lock Code of Nokia N8: We suggest to bring the Nokia N8 to nearest Nokia service center.
May 07, 2014 | Nokia N8 Cell Phone
nokia format nokia 5000d
Nokia 5000d hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 3110 Cellular Phone
locked nokia e86 how to format
Factory settings reset. In standby, dial *#7780# and the phone's lock code (the Nokia's default lock code is 12345). This reset restores phone's original settings.
Soft reset. In standby dial *#7370# and the phone's lock code.
Warning!Soft reset deletes all your phone's data, so backup your stuff before you do a soft reset!
Sep 11, 2012 | Nokia E72 Smartphone
forgot my phone lock
the only way out of this is , you have reset your phone, try getting reset codes from http://www.unlocking4u.com/ to master reset your phone back to
normal
Jul 14, 2011 | Cell Phones
dear sir, i forgot my wallet code so plese help me my hendset nokia 3230
If you forgot wallet code for Nokia 3230 phone,please use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Thank You
Aug 11, 2010 | Nokia 3230
270 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
