Tip & How-To about Cell Phones
How to view serial number of your nokia mobile phone?
To view the serial number of your nokia phone, press in *#06#..
Cell Phones Logo
WHERE I CAN FOUND MY SERIAL NUMBER IN PHONE e5
si no. or IMEI no. both are printerd in back side of your mobile that means under the battery. if no means press *#06# to display your IMEI no.
Sep 05, 2011 | Nokia E5 Cell Phone
nokia new models secret codes
View the firmware version of the phone
Dial using the keypad: * # 0000 # - the version number displayed on the display.
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Code activation.
*#4720* - Half Rate Code deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
*#7328748263373738# resets security code.
Default security code is 12345
SIM Clock
Stop allowed
Warranty Codes
* # 92702689 # [* # war0anty #]
Enter the menu of warranty codes. In fact, you do not need, but you can find them using the arrows scroll menu.
Menu:
1. Shows the serial number of the device.
2. Date and year of manufacture (eg 0299).
3. Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4. Date of last repair (if any)
5. Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
EFR CODEC (Enhanced Full Rate)
This function with its inclusion on the idea, should significantly improve the quality of speech, but unfortunately, it must be supported by your connection. When the work is slightly increased power in the phone call (about 5%). How do I know, none of the Russian cellular operators do not support this feature. Principle is based on a different compression algorithm for speech recognition (ACELP) and has a wider bandwidth.
Feb 28, 2011 | Nokia E71 Smartphone
all code sent my email
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
SimClock
SIM Clock
Stop allowed
Warranty Codes
Menu:
1.Shows the serial number of the device.
2.Date and year of manufacture (eg 0299).
3.Shows month and year of sale (if installed). Here you can set the date, but be careful - it can be done only once in their life phone
4.Date of last repair (if any)
5.Sends all the phone numbers, pictures, and calls from one phone to another (possibly in order to restore). In models with an infrared eye, this procedure works, and through him
Dial * 3370 # to activate (the phone should reboot) or # 3370 # to deactivate this function.
HR CODEC (Half Rate)
Substantially impairs the quality of speech, but saves battery somewhere at 30%. Again, must be supported by a mobile operator. American networks that support this feature, I do not know.
Dial * 4720 # to activate (the phone should reboot)
or # 4720 # to deactivate this function.
i hope this helpful
thank you for using fixya
Feb 09, 2011 | Nokia 5230 Cell Phone
please help.,.,i need my license key.,., imie 35227201819836.,., thanks
insert code :
and
like this example :
V 5.16
22-06-99
NSM-1
22-06-99 - date
View IMEI
i hope this helpful
Feb 07, 2011 | Nokia 6600
how to find the device serial number for 7230
If the number you are looking for is the IMEI or ESN (electronic serial number) you can usually view it by pressing * # 0 6 # (Star - Pound - Zero - Six - Pound) on your keypad.
Jan 15, 2011 | Nokia 7230 Cell Phone
169 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
