Tip & How-To about Computers & Internet
Backing your Data...
Computers & Internet Logo
what is required to remove the transmisson?
Well......it depends on the application....997 twin turbo 911....or a chevette.....
Apr 02, 2015 | Cars & Trucks
how do I fix a hand with a bandage that says page broken or removed
You can't do do anything with that page as the link is expired or it may be removed. The main reason behind it was that it may be removed by author. If it contains illigal things it may removed from site owner.
Dec 02, 2014 | Computers & Internet
cant remove the back brake cylinders. removed the 2 bolts in behind and still wont budge. help..
Have you removed the Brake Line? If not: this must be removed in order to remove the cylinder. Use a flare-nut wrench. If you have removed the Brake Lines and Bolts, tap lightly with rubber mallet to loosen.
Nov 24, 2009 | 1998 Dodge Durango
Acer Aspire 3680. How do I get the back off ?
For AS 3680,
Removed screen.
1. Open the door on the back to remove the wireless antena cables.
2. Open the power cover (remove 2 scews on the power cover).
3. removed keyboard.
4, remove 4 scews (silver scews) that make screen attched the the laptop body.
5. that's all you can remove the lcd now.
For opening the body,
1. Removed all screw on the back, include 1 screw (small scew) under hard drive.
2. removed 3 screws under keyboard
3. removed 1 scew on top side (close to power port), this scews held uppercase and lower case.
4. removed lcd lid cable from board (close to power port)
5. now you can separate upperbody from lowerbody.
6. removed 2 scews from motherboard.
7. removed modem cable, speaker cable, mic cable from the back.
8. that's all, you can removed motherboard+power board.
i hope this help you, good luck
Mar 02, 2008 | Acer Aspire 3690-2196 Notebook
111 people viewed this tip
David Payne
David Payne
