Tip & How-To about Cameras
Canon BP-511 Battery Maintenance Tips
Battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
Canon digital cameras come in several different lines, some compact for easy travel and quick pictures, and others larger with multiple lens options and more power. the same problem many users have to encounter is the battery.manufacturers will tell to them how numerous hours that Li-ion notebook battery can last, however, they don't tell you how to maintain the battery.
There are more tips for you to change a common battery life, extend it for digital camera. One more simplistic method of increasing the lithium ion battery life by defragmenting the disc and remove excess folders. The suggestion for keeping your device for canon digital camera run powerfully with the hi-capacity canon bp-511 battery, which is a replacement battery, can be used recycled.
A lithium-Ion battery for canon bp-511 has internal circuit board with chips that allow it to communicate with the digital camera to monitor battery performance, output voltage and temperature. It also gives the notebook much more accurate 'fuel gauge' capability to determine how much battery runtime is left before the next recharge is required.
The battery for bp-511 battery provides uninterrupted reliable performance for the canon digital camera no matter you are on the trip or on the train travel, and want to record the sight.
This least quantity of time draws a considerable effect on the complete replacement battery life existence, the lithium ion bp-511 battery is 1600mAh, in fact if the battery can be used correctly, the performance of the battery can be used as the original battery, just depends on yourself. When in the hibernate mode in & out are extremely favorable and efficacious than the usual start & shutdown operation.
Talk about the battery storage, storage the battery in the normal temperature. When in hibernate mode the shutdown procedure grants a alternative to pause present work immediately with the power-off and when in start up activity it will keep on with in a few seconds entirely, As a result hibernate mode saving power. Do not modify or disassemble the canon digital camera battery under any circumstances.
Do not store a replacement battery pack near chemicals and in a damp area as this will reduce Notebook battery ability. The replacement battery is made with chemical material, take care of it, if you can.
more canon camera batteries discount now,like
Canon nb-8l Battery US $ 10.54
CANON NB-5L Battery £ 8.58
CANON NB-4L Battery US $ 6.71
CANON NB-3L Battery US $ 6.71
CANON NB-2L Battery £ 8.48
CANON np-e3 battery £ 21.52
Cameras Logo
How can I get rid of the loud squeak in my Jenn-Air oven door?
Digital Camera Battery, Battery Charger Online Store. Canon, Panasonic, Samsung battery and charger online store -http://www.batteries-charger.co.uk is a sincere, trustworthy E-Commerce website since 2006. Provide cheap high-quality replacement battery and charger for Canon, Panasonic, Samsung, like: http://www.batteries-charger.co.uk/ http://www.buy-battery-charger.co.uk/ http://www.gateway-laptop-keyboard.com/ http://www.digital-camera-battery-charger.net/
Jun 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
samsung L100 camera, battery charger shows battery is fully charged, camera powers on, lens extends then immediately retracts and camera beeps three times
it sounds like a faulty battery try testing it with another battery and see if the problem persists if not then get a new battery,
let me know how it goes,
Jul 31, 2010 | Samsung L100 Digital Camera
camera won't turn on
1. Most likely is discharged or improperly inserted batteries. Make sure to use freshly charged AA batteries that are inserted with the correct polarity. The Inner 2 have the minus side up and the outer 2 batteries have the + side facing up.
2. Close the battery door fully because the battery cover pushes on a small sensor that has to be closed before the camera will turn on. The battery cover slides and clicks into place. If the battery cover sensor is bent or damaged then the camera would not turn on. The battery cover sensor is tiny, and out of the way and probably not obvious that is has one.
3. Insert the proper memory card and close the memory card cover securely. If it's left open or not seated fully the camera may not turn on. I
4. Also remove the memory card and re-seat it, then close the cover again in case it was not fully closed.
5. Remove the batteries and check that the battery terminals are clean and they appear to be intact. For example, corrosion from leaking batteries could cause a poor connection.
6. Was the camera dropped? If it was dropped that can bend the metal battery contacts, then when you put the batteries in it doesn't really contact the battery properly.
7. If it still won't turn on have an electronics guy check it over, or at the local college electronics teacher. I've fixed these before and the main DC circuits are not too complicated. These camera's can even be powered up using a regulated 6V DC power supply connected properly to the battery terminals, (just for testing) and in that case you don't need batteries to tell that the camera works or not. These draw about 300mA of current when ran from 5V to 6V DC.
I attached a JPG photo showing a similar Canon A60 running via a DC power supply and no batteries. This one was apart at the time to fix a stuck zoom lens, and when it's apart there is no where to put the batteries so I have to power it this way.
You do not have to take it apart or use this method. I just mentioned this so it's clear that all it needs to run is 5 -6V DC from properly charged and inserted batteries (or an external source). Don't try connecting anything if you are not familiar with electronics because connecting it up wrong can damage the camera. Try the suggestions mentioned early and it will probably work since these are pretty reliable cameras.
Jul 15, 2010 | Canon PowerShot A75 Digital Camera
my canon don't power on with a battery but power on with a charge can you help my to now what is the bad fuse? thank
try a new battery pack or let your's charge for 12 hres
about ;its seems that the battery pack you have is low in charge;because if its works with the chargerit should works with battery;about the bad fuse if it was the problem ,the camera will not work at all,
and that is a big problem that fuse is inside the camera on the pwr board,
hope that will help.
May 07, 2010 | Canon FS200 Flash Media Camcorder
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Feb 06, 2009 | Canon Cameras
201 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
