Tip & How-To about Computers & Internet
Removing Software Counterfeiting Message In XP
Ekse is right and this time I have done a post with deatils on on how to remove you are a victim of a software counterfeiting message in XP
http://fusionschronicles.blogspot.com/2010/06/removing-software-conterfeiting-message.html
Computers & Internet Logo
"You may be a victim
Welcome to FixYa!
If you're seeing notifications that the copy of Windows that is installed on your PC might not be genuine, or that you might be a victim of counterfeit software, it's likely that your copy of Windows was not properly activated or is otherwise not genuine. To fix this, click the notification and follow the steps to either repair Windows or-if you have inadvertently obtained counterfeit software-buy genuine Windows.
If you are using Windows XP, download and install the Windows Genuine Advantage Notification Application. It will scan your operating system and will remove the annoying message if it's a legitimate copy of windows.
Download here: http://support.microsoft.com/kb/905474
Keep me posted.
Thank you for using FixYa.
Jas247
Mar 14, 2011 | Microsoft Office Professional 2007 Full...
I can`t go in my mail,I want to remove you may be a victim of software counterfeiting
HI,
That message ("you may be a victim of software counterfeiting") is displayed when your Windows serial number is being used by someone else. If your copy of Windows is legitimate, try contacting Microsoft support.
Take care,
Alex
Oct 13, 2009 | Microsoft Windows XP Professional for PC
You may be a victim of software counterfeiting. This copy of Wind
you have a bootleg copy of windows. you will need to reinstall windows or you will not be able to update.
Mar 11, 2009 | Microsoft Windows XP Home Edition
Victim of software counterfeiting
This means the Windows Validation Tool has checked your installed copy of Windows and has found it to be a non-genuine copy. This means the product key is non valid.
Where did you get the PC? If a "friend" installed Windows for you then he is using illegal product keys.
If you are sure your Windows is genuine, you need to telephone Microsoft and fight it out with them.
Jan 02, 2009 | Microsoft Windows XP Professional for PC
After installing your genuine copy of Microsoft Windows XP you are prompted with a “Your software is counterfeit” error message at startup. Even after visiting the www.microsoft.com/genuine/ site and validating, you still get the above message popping up after 2 or 3 boots. There is an easy solution to this and I would like you to follow the steps below to fix the issue.
1. C:\Windows\Downloaded Program Files
  • Within that folder, remove any files or folders associated with .WGA
2. Safe Mode
  • Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.
  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…
  • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)
  • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)
    Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,
    Select the view Tab and under the Hidden Files option, select Show hidden files and folders
3. Safe Mode Registry
  • Click on Start, Run and within the open dialog box type regedit and click OK.
  • Within the Registry Editor navigate your self to
    HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersion\Winlogon\Notify\WGALOGON
  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)
  • After Exporting the folder, DELETE the WGALOGON folder
  • After deleting close all applications and Restart your machine back to Normal Mode
After being prompt of a successful validation, Restart your Machine.
Oct 31, 2008 | Microsoft Windows XP Professional for PC
118 people viewed this tip
David Payne
David Payne
