Tip & How-To about Dishwashers
Maytag recalls dishwasher/fires feared from heating element
Maytag is recalling dishwashers for fire hazards including Maytag, Amana, Jenn-Air, Admiral, Magic Chef, Performa by Maytag and Crosley brand dishwashers with plastic tubs and certain serial numbers.
Check these serial numbers to see if you have the dishwasher in question.
Call 1-800-544-5513 if you think you have one.
Dishwashers Logo
Removing the Idler Pulley Assembly
Whirlpool manufactured brands including Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Glenwood, and Caloric. All of these front loader conventional electric dryers are very similar. The idler pulley attaches by a snap in spring assembly.
26031432-cqk4auvkq54bteptus3ub0nf-1-0.jpg The spring assembly is purchased as one part with the idler wheel attached. If the make of your dryer is different than the above please provide additional information.
Dec 31, 2015 | Haier HLP140E Electric Portable Dryer
for a ge dishwasher mod#ghda485nools:on startup mode lights blink and pump turns for 10 seconds then shuts off
00023396.gif small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
transparent1.gif Find a part for your Dishwasher godark_3.gif How Dishwashers work godark_3.gif What is wrong with your Dishwasher? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Dishwasher godark_3.gif Answers to common questions about Dishwashers (FAQ) godark_3.gif Locate your Dishwasher model number godark_3.gif Accessories for Dishwashers godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Dishwasher and get free Dishwasher repair advice for all major brands of Dishwashers including Admiral, Amana, Asko, Bosch, Caloric, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Glenwood, Hotpoint, Insinkerator, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, RCA, Roper, Tappan, Thermador, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jul 04, 2008 | GE Dishwashers
MDB7130AWB thermal fuse
This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
Thermal Fuse
PartSelect Number PS342838
This part is used as a safety device to protect the dishwasher circuit from overload. If the temperature gets to high it will shut off the electrical current to the heating unit in the appliance.
This part works with the following brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Caloric & Glenwood.
This part fixes the following symptoms:
  • Not drying dishes
  • Will not start
See part 26 in the diagram
Apr 08, 2013 | Maytag 24 in. MDB5600A Jetclean II...
door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
529 people viewed this tip
Top Dishwashers Experts
