Tip & How-To about Office Equipment & Supplies
Brother MFC laser printer facsimile machine replace drum or change drum soon reset procedure
OK so you have replaced the drum unit on your Brother, or you have not replaced it but your copies are fine and you want to extend the life of your drum unit.
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya.
its having a drum error. please help now
First did you follow instructions of reseting machine , if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
  1. When you replace the drum unit with a new one, or just want to extend the life of your existing drum unit, you need to reset the drum counter by completing the following steps:
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
  6. --------------------- This should help.Thanks.Helpmech.
Jan 25, 2011 | Brother HL4040CN Laser Printer
drum end soon
    "Reset Parts Life".
Jan 09, 2011 | Brother HL-4040CN Laser Printer
how do I reset the drum counter on the a Brother MFC-7840W???
open the front cover of the machine then press clear back it will say replace drum? press ok
the quality will probably start getting pretty bad as you will be using the drum passed it's life
Mar 22, 2010 | Brother MFC 7840W Printer
Brother DCP-9045 CDN end of drum life override, how too? I have a Brother DCP-9045 CDN and it tells me the Drum Unit needs replacing. However it works fine and I am convinced there is more life in them. Does anybody knew how to override this? Thanks.
Turn your printer off. Turn it back on again, go to menu -> Machine Info -> Reset Menu, choose Belt Unit, OK, then reset the counter pressing 1, then press stop/exit. Same for drum.
If however this won't work, go to the following page and look at the instructions. Do what it says, but just pull out the drum unit and put it back in, the same with belt unit, just pull it out and put back in.
Then do the reset procedure as described. Should fool the printer ;)
Link: Brother instructions
Nov 28, 2009 | Office Equipment & Supplies
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
2,405 people viewed this tip
k24674
jasbo
jasbo
