Tip & How-To about Cell Phones
Resetting IMEI & Bluetooth Address on LG Phones
In order to change IMEI and Bluetooth address, you need the following tools:
QPST:
http://rs50.rapidshare.com/files/213..._build_231.rar
NV Editor:
http://www.siemensplanet.com/SandSto...s/NVeditor.zip
The tutorial to enable the BT adress item with IMAGES .rar
http://www.siemensplanet.com/forum/d...669853347d5b77
NOTE: many of these work are written by someone else on a different phone, but!!! they all use Qualtumm Baseband!
If you had problems downloading, go to this page:
http://www.siemensplanet.com/forum/viewtopic.php?t=4378
Same tools can be downloaded from there!
All these phones are exactly the same internally!
START FROM HERE:
Updating IMEI:
1. Turn the Phone Off, disconnect it from the PC, turn it on, re-connect it to the PC.
2. Go Start -> (All) Programs -> QPST -> QPST Configuration.
3. Click on the PORTS tab.
4. If your phone is NOT listed... Click the ADD NEW PORT button in the lower right...
5. From the list of ports in the box on the left, click the entry that says COMxx - QC/Diag modem and click OK.
6. You will be brought back to the main QPST Configuration program displaying the "ports tab" this time with your phone listed as SURF6280 in the phone column...
7. You are now ready to make use of QPST and its features.
8. Use the Start Client pull down, click on Service Programming.
9. ake sure your phone is selected, and click OK.
10. Click READ FROM PHONE button in the lower left.
11. For the Service Programming code... use 000000 (should be filled in that way anyway).. and click OK...
12. After it reads the data in... go to the IMEI section on the first tab(NAS).
13. TAC is the first 6 digits of your IMEI, FAC is the next 2, SNR is the next 6.
14. The 15th digit of the IMEI is calculated by your phone, DO NOT enter the 15th digit.
15. Click on WRITE TO PHONE button in lower left.
Note: This can take 1 minute, be patient!
16. Wait for the read from file button become clickable again or simply wait 5 minute then Go to connection---close.
17. Power the phone off, wait a few seconds.. then back on.
IMEI Restored.
Bluetooth Address:
Since you upgraded the phone, you already have the usb drivers.
1. Now, launch the QPST configurator.
2. Click on "add new port"
3. Type the port number your phone is using now. (you put it COM5, COM10, etc, its just one example)
Note: If you already added your port in QPST then skip this.
4. Now, launch the NV editor, maximize the window.
5. On connect, select the com port, and press connect server.
6. Press the file button and select upload all from mobile
7. Press the search button, and type "447"
8. Move the file to the "selected" window, once you double click it, in another window you will see loads of fields with 0
9. Change the 0 to 1, on all of them. Also, change the string value to "true" 10. Now, you press the "file" button and press "download selected & active to mobile"
11. Disconnect the server, close the program, unplug the phone, and restart the phone.
12. Now, try to enable the bluetooth.
Remember, once you do the 6th image step, you go to connection and select disconnect server.
Cell Phones Logo
how to connect my phone to my pc?
download all this file and put in a folder and click on part01.rar.and used it;the link are
http://rapidshare.com/files/32855528/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part01.rar 50.00 MB
http://rapidshare.com/files/32862936/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part02.rar 50.00 MB
http://rapidshare.com/files/32874284/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part03.rar 50.00 MB
http://rapidshare.com/files/33021588/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part04.rar 50.00 MB
http://rapidshare.com/files/33042858/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part05.rar 50.00 MB
http://rapidshare.com/files/33055195/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part06.rar 50.00 MB
http://rapidshare.com/files/33062921/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part07.rar 50.00 MB
http://rapidshare.com/files/33198405/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part08.rar 50.00 MB
http://rapidshare.com/files/33236504/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part09.rar 50.00 MB
http://rapidshare.com/files/33443943/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part10.rar 50.00 MB
http://rapidshare.com/files/33532042/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part11.rar 50.00 MB
http://rapidshare.com/files/33534977/Motorola.Phone.Tools.v4.0._RAZR.v3_v3i_v3x__SLVR.L7__L2_L6__E1070_E770v__A780_.part12.rar
Nov 26, 2009 | Motorola Mobility RAZR V3
when i ture my bluetooth something popup that you must set bd address please help me
The address isn’t something that can be set, that’s a MAC address - it’s the unique identifier for the bluetooth chip on the phone (all network cards have them).
I would hazard a guess that either your bluetooth stack on the phone is goosed or the chipset itself.
OR
Try this:
Turn the Bluetooth Off, disconnect it from the PC, turn it on, re-connect it to the PC.
Bluetooth Address:
Type the port number your phone is using now. (you put it COM5, COM10, etc, its just one example) -----------------If you already added your port in QPST then skip this.
on connect, select the com port, and press connect server.
press the file button and select upload all from mobile
Then, press the search button, and type "447"
Move the file to the "selected" window.
Once you double click it, in another window you will see loads of firlds with 0
Change the to 1, all of them.
also, change the string value to "true"
All fixed!
Good Luck & Thanks,
Shiv.
Aug 20, 2009 | LG Shine KE970 Cellular Phone
codigo de autorizacion
try using FOXIT PDF SUITE: A very tiny yet powerful PDF Suite it includes PDF Reader, Writer/Creator n Organizer
Download Links:
http://rapidshare.com/files/187040214/Foxit.PDF.Reader.Pro.2.2.2129_Foxit.PDF.Editor.2.0.Build.1011_Foxit.Library.RAR
http://rapidshare.com/files/230996533/Foxit_PDF_Suite_Completa.rar
http://rapidshare.com/files/126061245/Foxit.PDF_Suite.NoMad.ImediaR.rar
Jul 26, 2009 | Adobe Acrobat 7.0 for PC
Audio Driver Installation Failed.
First guess is you have the wrong driver but I am seeing others having this problem as well. Either that or you post to a ton of boards.
OK first correct chipset drivers. http://www.nvidia.com/object/nforce_630a_winxp2k_14.10.html
That would help audio drivers identify your audio card.
Next are the right audio drivers. The list includes other drivers you might need. Do not use the chipset or graphic drivers from this site as they are outdated.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3180330&lang=en
Hope this helps
Jan 26, 2008 | Compaq Presario Modem/NIC Combo...
1,641 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
