Tip & How-To about Computers & Internet
CD/DVD drive drawer fails to open ?
I've often seen this problem on Fixya, there's a quite well known solution.
The CD/DVD drive drawer on your PC (laptop or desktop) won't open when you press the button.
Look closely at the front of the drive, usually, just below the draw itself but still on the front bezel of the drive, you should be able to spot a small hole.
This is the manufacturers fail safe release mechanism, all you need to do is straighten out a paper clip, or use something similar, a push it into the hole, quite firmly. This should release the draw and it will pop out part way.
Invariably after doing this, the drive draw starts to function again normally.
Computers & Internet Logo
how do i open a disk drive to a acer aspire e touch
well it sounds to me like you are just trying to open the drive to insert a disk ? go to "computer" or "my computer" on the desktop, double click to open. you should see your hard drive "c" and cd/dvd drive "d" listed. right click the "d" drive, left click eject, voila. if you have more than one hard drive or a partitioned drive there might well be more drive letters but your cd/dvd drive will be marked as such. alternatively click "start", bottom left of desktop, click "computer" and once again you should see your drives listed. physically there should be , on the cd/dvd drive drawer itself a small button, push it once to open. failing all else, there should be a very small hole in the drive drawer, using say a paper clip or similar, insert into the small hole and push reasonably firmly, this should release the drawer manually and the drive will open. hope that helps. good luck.
May 11, 2014 | Acer Aspire 5315 Notebook
Aspire dvd drive won't open
If you open Start Menu,Computer, DVD/CD rom, and right click, eject? If it is damaged or there is something in it you may have to remove it and clear the obstruction.
Nov 29, 2012 | Acer Aspire X3200 PC Desktop
Stuck CD/DVD drive. Won't open
There is a hole on the front of the drive. Push an unbent paper clip into ththe hole and it should release the drawer.
Jul 04, 2012 | Acer Aspire X1300 (PV.SCC0X.002) PC...
cd won't open
On the face of the CD drawer there should be a small hole the size of a paper clip. Push a paper clip end into the hole, this should release the door and it will pop open.
May 08, 2012 | Everex IMPACT GC2500 PC Desktop
Brand new ASUS desktop DVD/CD R-W drive won't open.
hold the faceplate open, get a paper clip. There is a small hole in the front of the DVD/CD drive, place the paperclip in it and push slowly until the device drawer opens.
Jan 21, 2012 | ASUS Essentio Desktop with Intel Pentium...
235 people viewed this tip
David Payne
David Payne
