Tip & How-To about Computers & Internet
How to maintain a healthy Desktop or Tower computer
HARDWARE MAINTENANCE
A computer system is like a machine,if you use it everyday after a while it will need some maintenance in order for it to keep on working in a healthy manner. There are lots of things that can affect the healthy function of a computer, for example dust cause many computer to become too hot and the heat can shorten the lifespan of the computer components which are located inside of the computer case.In this writing i will teach you how to keep you computer healthy without spending much money. you should clean you computer at least every six ( 6 )months.The first step is to but a one ( 1 ) inch paint brush and a can of compress air, the second step is to remove the left side cover of the computer case your computer may already have lots of dust inside so you should it outside and use the paint brush to brush as many dust as possible out of the computer but be careful not to cause any component to move out of position. Then you will use the compress air to blow out the remaining dust from the computer, try to blow the the dust from the CPU fan and other system fans in the computer.Usually these fans trap a lot of dust over time and this cause the fan not to push the right amount of air to keep the system cool can cause some components to over heat. After you finish cleaning inside the computer you will put back the cover in the way you took it off. your next step is to remove the keyboard from the computer by unplugging it from the computer and use the brush and compress air to clean it.
The next step is to clean the monitor, there are several types of liquid monitor cleaner available in computer stores.For example PC Clean Advance Formula is use to clean monitors along with a lint free cloth spray the monitor cleaner on the lint free cloth and wipe the monitor carefully, make sure the monitor is turn off before you attempt to clean it.
You can give me you vote and rating after viewing this tip Thank you
Computers & Internet Logo
what does shaft maintenace due mean
It means your machine needs to have seals and bushings replaced. This maintenance should be performed twice per year to keep your Bunn Ultra 2 in working order. This is something you will need to call a technician in to do.
Feb 20, 2015 | Bunn Margarita Machine Ultra 2 Slush...
I have a sharp AR 5625 photocopy machine that brings a message 'maintenance is required ' how do i solve it?
Are You the Administrator for the System?then go to the folder On the computer it's connected to and run Diagnostics from there, And Or from the control Panel/ Devices/Hardware,Also Right click Computer go to Properties device manager click on Printers if you have a yellow Icon on anypart of that list then y have a software Problem, go to MANUFACTURE Web site and Download the latest sofware for you're machine restart after install and you should Be fine , ALSO DON'T forget to run you're computer tools Like disk clean up and disk defragmenter, to keep you're System in top working order
May 24, 2012 | Alienware PC Systems ALIENWARE 5620D...
i reformatted my pentium 4 windows XP last time and my computer has no sounds.i want to install some online games. how should i install the rigth sound driver for my computer? thanks i hope that you could help me..
You should check with the Driver CD that came with your system upon purchase. If you dont have it or lost it, try searching for AC97 audio drivers online.
Jun 04, 2011 | Computers & Internet
201 people viewed this tip
David Payne
David Payne
